- Nov 22, 2010
- 371
hey all,
I got a later model 10 K w/ horizontal drive and it is missing the spring and cap that the countershaft sits on when belt tension is relieved.
The rebuild manual has a good picture of it and it doesn't look too technical.
if someone could give me some measurements and details I'm sure I could replace my missing parts with hardware store spring and a machined cap for the spring.
one end of the sprong sits in a short tube at the base of the plate mounted to the bench the other end of the spring , I believe, catches a screw shaft that would hit the cap on the spring.... it appears that the set-up cushions the countershaft when the tension on the drive belt is taken off so things don't "slam"
Any help would be greatly appreciated
joe
joe
