- Sep 22, 2010
- 7,223
Here is a topic we haven't covered!
Painting experts front and center, please!
You tried spraypainting ome parts last week using Tremclad 'Professional' enamel paints, but the paint is still dentable with a fingernail. You even tried putting the parts in front of a heater for a few days with little effect. The paint says to wait 10 to 20 mins beween recoats, with a max time of 1 hour or wait 48 hours. Did the following with the part in front of the heater, so it likey got 20~30c air passing over it. Painted 3 layers of primer, with 15 mins wait time beween, The coats where think enough to have good coverage, but not quite 100% coverage with each coat, more like 75%, so no runs. Waited about 10 extra mins for the paint to dry, then fliped the part over. Painted the back side with 3 coats of primer, 15 mins inbeween coats. Waited about 10 extra mins for the paint to dry, then fliped it back over. painted 3 coats of black, 15 mins apart, about the same coverage as the primer each coat. Waited about 10 extra mins for the paint to dry, then flipped it back over. Painted 3 coats of black, 15 mins apart, about the same coverage as the primer each coat.
Basically, you put 3 coats of primer on each side of the part, and then 3 layers of black semigloss topcoat, with about 55 mins beween primer and topcoat. Even after 25 mins, the primer still not fully touch dry, and where the primer contacted the block it rested on, it riped off on the next part flip. You think you have have to suspend the parts and paint both sides at once.
The main issue with the resulting job, is its just still soft even after a week of drying infront of a space heater.
Questions:
Should you have used thinner coats? It seemed pertty much 100% coverage after the 2nd coat, but I put a 3rd on to insure it was thick.
You want a durable paint and assumed thickness+number of coats is the way to get it. Is that wrong?
Should you wait the 48+ hours recommended after X number of coats? What is X number? Should you wait even longer?
Should you do less or thinner primer coats and let it dry before topcoat?
Does a primer even need 100% perfect coverage or should it be more like a very light, slightly spotty coat?
Thank you!
Nelson
Questions:
Thank you!
Nelson
