Similarly my suggestion is not a direct response to your actual question, but might help: Get an electric lawn mower. I have a 13 amp Greenworks model. I got it for $150. It bags, mulches, or side-discharges, just like most gas mowers. Plenty of power for normal lawn maintenance. And it's SO lightweight (honestly, my 8 year-old daughter could handle it if I trusted her with a spinning blade) that the lack of self-propelled drive hasn't bothered me for one minute in the two years I've owned it.
It couldn't be simpler. It has a DC motor directly driving the blade (with permanently sealed bearings), there's a bridge rectifier to convert the AC power to DC, and the safety switch and power cord. There are no other parts to go bad or replace (I suppose a wheel might break down eventually??). The only maintenance I've done is sharpening the blade a couple times per year and a few weeks ago my wife tried to mow grass taller than the mower with it and the bridge rectifier burned up. I bought 4 new ones for $12 (including shipping from Florida), and it only took a few minutes and seven torx screws to install the new one (once I had it). I can't even get the air filter for my (recently inherited, riding) gas mower that cheap.
Honestly, I couldn't be happier with this thing. I thought that having an extension cord would greatly complicate mowing, but where this nice electric was as cheap as the cheapest gas mowers and all of their issues, I decided to try it. It turns out if you've ever managed a power cord while vacuuming then you know how to manage a cord while mowing. Just start on the side of the yard where it's plugged in and then work away from there.
- No Winterizing
- No Spring tune-up
- No gas
- No oil
- No oil changes
- No air filter
- No spark plug
- No rip cord
- No choke
- No throttle
It's quieter than a gas mower (the blade still makes a fair amount of noise, obviously). The handle collapses and it takes up very little space, with no concern about storing it vertically, either. I can see the appeal of the battery-powered units, but honestly I have no wear-and-tear on expensive batteries (nor did I have to purchase them up front), nor delays while waiting for them to charge. Just an extension cord. And at 13 amps a 14 gauge cord is sufficient for most yards.
I really didn't expect to be this pleased with an electric mower. I would recommend it to anyone.
