Spinning Tops
scwhite
Active Member
Active Member
Mar 19, 2017
313
Likes
237
#92
Cool! If you wouldn't mind sharing, can you post a picture of your rotary table setup? I have a small import rotary table that my dad gave me, but I honestly don't understand how to affix work to it. It doesn't really have a center taper, and the table doesn't appear to be made to hold a chuck. I don't really get it. This is the only picture I have on hand at the moment. I think it's probably a 4" table or so.
Also- did you see the video above of my milled top spinning? Pretty freakin' proud of that one!!
You can make a adapter with a plug to fit in that hole on you rotary table slide in four T- nuts and bolt it to the table on the roatary table with a plug to fit the back of you chuck and bolt the chuck to the adapter
Plate . Should be easy
rwm
H-M Supporter-Premium Member
Mar 25, 2013
1,048
Likes
1,131
#93
I saw the video. Great!
My table has a threaded center hole. I have an adapter that fits that hole and the other side fits the 3/4-16 threads of a Sherline chuck. I hold the disc in that chuck for machining. Looks like you could do that with your table.
Robert
rwm
Mar 25, 2013
1,048
Likes
1,131
#94
this milling create air drag
There are tops that are meant to spin a long time and there are tops that are meant to look good. Rarely are they the same tops.
I'm pretty sure this won't work well for a top...
Robert
wildo
Active Member
Active Member
Dec 7, 2015
381
Likes
346
#95
Made this little guy last night. This is another three piece, but this time the pieces are stacked vertically rather than axially. The bottom ring is cast iron, and the top ring is titanium. This is my first titanium turning. I also did some milling (18 evenly spaced milling slots) on the titanium. The stem is brass. This one spins REALLY well, but unfortunately I set the bearing just a bit too deep. It still spins well, but it's a SUPER lowrider.
rwm
Mar 25, 2013
1,048
Likes
1,131
#96
Slick! I see you are not afraid of new materials!
Robert
wildo
Active Member
Active Member
Dec 7, 2015
381
Likes
346
#97
Robert
Heh- I don't know what I'm doing anyway, so why not try out some new stuff!? Actually, I found turning/shaping of the Ti pretty easy, perhaps not so different from aluminum even. Even the milling went pretty well. But sawing off a chunk in my horizontal bandsaw took FOREVER and parting on the lathe was a nightmare. Not sure what I was doing wrong with those operations. Overall, I'd work with it again. I was really shooting for the ability to get some fancier colors on the stem, but then changed gears and went with a brass stem anyway. But here was some practice with flame coloring the titanium:
DHarris
H-M Supporter - Premium Member
Dec 1, 2016
99
Likes
87
#98
If Ti is too hard to work with, you can do the same flame coloring of stainless steel from light straw brown/gold to dark blue too! Might be easier to work with.
wildo
Active Member
Active Member
Dec 7, 2015
381
Likes
346
#99
Yes, that's true but I found (and have seen from other makers) that the color vibrancy of titanium is significantly more than that of stainless. I have made a top using a stainless stem that I flame colored- and it's cool looking- but it's nowhere near as vibrant as the titanium is. I think this is one major reason why titanium is the "go to" metal for spinning top stems in the higher end tops.
wildo
Active Member
Active Member
Dec 7, 2015
381
Likes
346
Made this little guy tonight. Cast iron over titanium with milling all the way around. Spins almost dead still. Body O.D. is .625" or, in other words, it's really tiny! Pretty dang proud of this one!
Still working on better flame coloring- just not getting the colors I want. And also, while my knurls are not double tracking (I'm starting with the proper o.d.) I'm just not getting them as crisp as I want. Not sure what I'm doing wrong on that. In real life they look great, but I've seen some pics from the best of the best makers where their knurls are unbelievably crisp. Even still- this top rocks!
wildo
Active Member
Active Member
Dec 7, 2015
381
Likes
346
What are you up to lately, RWM? Make any new cool tops? Here's my latest. These tops were designed specifically for the TopCon 2017 spin competition. The rules were:
  1. Top has to be 10 grams or less.
  2. Top can be at max two pieces, and must be made of timascus (I was practicing with titanium)
  3. Center stem could be at max no more than .500"
...Otherwise, anything goes. I figured that most people would use aluminum or magnesium for their stem, so I opted for something even lighter- Rexolite machining plastic. Fun stuff to work with! The stems on both tops shown in the video are less than 1 gram. I was REALLY hoping to break the 10 minute mark, but I just couldn't get there- not even close to be honest. The first top is 8.8 grams and the second is 9.85 grams. Personal best spin time for the first is 08:24.20 and 07:16.77 for the second. They are a bit scratched in the video due to MANY spin attempts.
rwm
Mar 25, 2013
1,048
Likes
1,131
Beautiful stuff you are making!
As you may have seen, I have been busy with a top that uses a Harley wheel turned sideways on an axle...
Robert
wildo
Active Member
Active Member
Dec 7, 2015
381
Likes
346
Robert
Actually I have not seen that. Did you make another thread or something? Would like to see it!
rwm
Mar 25, 2013
1,048
Likes
1,131
There is a guy making tops out of iron meteorite fragments! Pretty cool idea. That stuff is crazy expensive though. I guess for some special project that would be a really interesting material to use. It something I will keep in mind.
Robert
wildo
Active Member
Active Member
Dec 7, 2015
381
Likes
346
It has been a while since I've posted here, but I've been busy! Here are pics of the last eight tops I've made. Enjoy!
[EDIT]- Good God. Darn Photobucket.
Container Above bottom breadcrumb
