I recently purchased a PM940 mill and I'd guess this applies to most of the RF45 based units as well. When I made my purchase I ordered the 3 phase 1.5 hp motor along with WJ200 VFD.
I got everything hooked up and it works great so far. Seems very powerful for what it is. Though I have a few questions, hopefully some of you with experience might be able to help with:
What do you think a "safe" limit would be with regard to Hz? I realize the motor is rated at 60. But overdriving them seems to be pretty common practice.
Along with that, what about the spindle bearings? What speeds have you guys seen them be able to handle without grenading?
I asked Matt via email and as I suspected, he only recommended running both at the rated speed. Hard to warranty something and recommend it run at higher speeds. I thought I'd ask anyhow.
That said, I ran mine for a bit, not cutting, through each of the gears during testing. Kept it at or below 60hz. After not long, the spindle got pretty warm to the touch. Warmer than I figured it should. Motor wasn't warm at all. Is this normal?
The oil in the head wasnt all that clean looking to start with, but I wouldn't call it dirty. I do plan on changing it in short order. I also plan to change the stock bearings at some point, just not right now.
Given the kind of "stuff" that might be floating around in there, the oil, and the spindle being so warm... I'm inclined to strip the head down like I have the rest of the machine and give it a good cleaning and an oil change... Before the bearings see much abuse. I'd like them to last until I actually want to change them.
That said, I was quite surprised by how quiet it is while running, even flat out. Most of the noise is just the motor and it's fan. Granted, all the gears are submerged in oil.
