Spin indexer
Scruffy
Jun 5, 2013
549
I’ve never posted a project, so here go’s .i was given this index a few years ago and use it ocaissonaly , it uses Jacobs rubber flex collets which I have from 1/16 to 1 3/8 ths.
The index plate only has 6 divisions , so i’m Going to make one with 24 divisions, I think
Here’s my start.thanks Ron
Ps I think some one used pieces and parts to make this. Look at the welds. I can’t find any markings on it0A07F509-81AF-4CA8-A247-967E7F3EDEB1.jpeg890CA275-8E2B-45CD-8DEE-1C185B752635.jpeg40DFC48B-4083-4E91-8084-AFA55851B948.jpegF9352CB7-0316-496F-A335-61370B53D92C.jpegFBC33152-A495-496E-9B4D-33FE11AA30D5.jpegC22AEFE6-EB80-49AF-B9EF-AABDC39E1202.jpeg418EADE6-F7C6-4EB9-A09D-A9EEC1D5B025.jpeg0A07F509-81AF-4CA8-A247-967E7F3EDEB1.jpeg
I agree with Ulma Doc. This looks like a fun project!
I kept for getting to take pictures here are the ones I rembered. After turning the step and od. I parted it off then drilled the center to use a boring bar to get finished I’d.
Then I turned a mandrell to chuck in a super spacer. Threaded the arbor to fit a nut I had. Could’nt Get it to fit. Left hand threaded nut. Oh well turn down to 1 inch and start again.
Mounted in the super spacer on the mill l tried using a gear cutter, all I got was a lot of noise, so turn the spacer the other way and used a 3/16 end Mill and it worked great. The green stuff on the threads is scotch Brite pad did’nt help it fit a left handed nut
