- May 16, 2016
- 1,694
Can anyone advise on a speed control for a 240v single phase 50hz. motor 1.5 hp.
Thanks Bob.
Thanks Bob.
Assuming these little gizmos are no good at all, they say 220 V AC., Might they work on 110 V AC? if so, how should it be wired. I have one, it has four screw terminals. The two on the ends are common, ie., they are connected with a trail of solder to each other and appear to connect to nothing else. The left hand pair say "IN", the right hand pair say "OUT."The two in the middle go to the thing mounted on the heat sink. If I wanted to control a fan, how would I wire it?
