    Dismiss Notice
Special Internal Thread Advice
Discussion in 'QUESTIONS & ANSWERS (Get Help Fast Here!)' started by davidh, Aug 11, 2015.
  1. davidh
    davidh United States Active User H-M Supporter-Premium
    153
    63
    beautiful, sunny, downtown, northwest wisconsin.
    City:
    Maple (near Superior / Duluth)
    State:
    Wisconsin
    -Return to Top-
    I'm building a cnc router and have the thing ready for the ball screw nuts to mount. they are a simple, male threaded part that is .938-16 tpi. i need to drill / bore and thread the mounting plate for three of these. what inside diameter should i bore to, or where is the formula to calculate this ? thanks in advance. . . .
  2. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    2,329
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    Bore diameter is .870 to .884"
    Bill C. likes this.
  3. davidh
    153
    63
    City:
    State:
    Wisconsin
    -Return to Top-
    how did you arrive at that number ? if you would share ?
  4. Jeff M
    Jeff M United States Iron Registered Member
    12
    3
    City:
    Woodstock
    State:
    New York
    -Return to Top-
    Not my post but here is how I get there quickly.
    7/8" tap drill. I cheated. 3/8-16 tap drill is 5/16 so a 16 tpi thread, no matter what diameter you start at is 1/32 per side. The formula's are easy to find but it is quicker and easier to cheat.
  5. davidh
    153
    63
    City:
    State:
    Wisconsin
    -Return to Top-
    well, i tried, and failed on the first try. . . . then i found this:
    "maj. dia minus ((.01299 times the percentage of engagement) divided by the threads per inch)
    being i failed algebra / geomerty i will attempt to decipher that formula into my needed number.
    .938 minus ((65 x .01299) divided by 16 = x
    .938 minus .05277 = 0.88527
    x = 0.88527
    sounds and looks logical
    is that correct ? ? ?
    so my hole was bored to .892 /.895, then threaded about .052 on the half dial, i think. really hard to see the itty bitty numbers. . . and i did three spring passes to where there was no more material coming off the cutter. the part would screw on about half way and stop. . .
    the poor little lathe was vibrating about half way thru every cut. . . . . and of course i can see the vibrations in the threads so, into the scrap bucket with the first one, and time to try again. . . if the numbers are correct.
    thanks for the help.
  6. Bill C.
    Bill C. United States Active User Active Member
    152
    63
    City:
    Clarksville
    State:
    Indiana
    -Return to Top-
    I found this on another website, "Tap drill size for .938-16 (15/16-16) would be 7/8" or .875". I hope you are successful with your threading project.
  7. RJSakowski
    RJSakowski H-M Supporter - Premium Content H-M Supporter-Premium
    2,607
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
    At .892/.895, your bored hole is oversized. You calculated .885" for 65 % thread engagement. The 7/8" bore given by Bill or the .870 -.884 range from 4gsr are good sizes. If you are advancing out .052 inches, the major diameter of your thread will be close to 1" (.892 + 2 x .052 = .996). Your 15 thread should go in easily. Have you checked to make sure that you are cutting a 16 tpi thread and/or that the thread you need is actually 16 tpi? With an oversized internal thread and the wrong thread pitch, you would get a partial engagement as you describe.
    Bob
  8. mikey
    mikey Active User H-M Supporter-Premium
    2,575
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
  9. Tony Wells
    Tony Wells United States Former Vice President Staff Member Administrator
    19,407
    113
    Tyler, Texas
    City:
    Tyler
    State:
    Texas
    -Return to Top-
    4gsr likes this.
  10. 4gsr
    2,329
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    I have a spread sheet set up with the calculations for class 2 fit UN vee threads and class 2G Acme and Stub Acme threads. All of the numbers are calculated by using the formulas listed in the ANSI Specifications for threads. (I don't remember the specification numbers, its been several years ago since I did the spreadsheet.)
    I have uploaded the spreadsheet in the "down loads" section for anyone who wants to use it. I take no responsibility for any errors occurred from it's use. So far in 22 years of using it, no one has complained....
    http://www.hobby-machinist.com/resources/thread-program.2496/
  11. Wreck™Wreck
    Wreck™Wreck United States Active User H-M Supporter-Premium
    1,357
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    Major Diameter = the thread lead is close enough for such work.
    In this case the lead is .0625" - .9375"
    .875.
    I should note that the Thread Lead and Pitch Diameter are the most important numbers, this will allow your parts play nice with others using the same standards.
  12. seasicksteve
    seasicksteve United States Active Member Active Member
    84
    28
    City:
    central
    State:
    Ohio
    -Return to Top-
    Macinerys Handbook is a great resource for this info
  13. kd4gij
    kd4gij United States Active User Active Member
    1,180
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
    Are you sure that it is 16tpi and not metric?
Share This Page
