- Nov 22, 2010
- 371
I own a heavy ten now but I am helping a friend set up a workshop 9" We want to change it to the lever tumbler like my 10L , We bought a lever assembly on flea-bay and and have a 1/2 Inch spacer as required for the 3 holes needed ( fwd-neutral-rev)
Problem is ....The big lole in the 9" for the assembly is 1.00" in diameter and the replacement unit we bought is 1-3/16 " dia. it must have come from a larger machine ( 13" 16" ?? ) shouldn't the unit from a heavy 10 work?or must it come from a 1oK?
we will buy the correct unit and I will sell the larger unit but I need to know what my larger one fits and from which South Bend model to we need to buy the correct tumbler from.
As always .....My sincere appreciation for your help
Joe
PROBLEM SOLVED
I just found my problem solution I needed a revers tumbler from a 10K thanks anyway ...
Joe
PROBLEM SOLVED
