    Dismiss Notice
South Bend oil pump
Discussion in 'SHAPERS & THEIR USES' started by buggsy, Mar 19, 2017.
  1. buggsy
    buggsy United States Active Member Active Member
    3
    8
    City:
    ashby
    State:
    Massachusetts
    -Return to Top-
    Hi, Just got through rehabbing a SB shaper I picked up. I ran it for about an hour and half not cutting, waiting for oil to come up. No oil. How long does it take to prime itself or do I have to prime it somehow?
    Buggsy
  2. CluelessNewB
    CluelessNewB Active Resistor H-M Supporter-Premium
    346
    83
    United States Southern Maine
    City:
    Gorham
    State:
    Maine
    -Return to Top-
    Mine primed itself but when I got it and drained the old oil it looked almost new so I can only assume the previous owner changed it often. I did end up actually turning down the flow a bit because it was making a big mess.
    I assume you have a copy of the South Bend "How To Run A Metal Shaper" if not you can down load a PDF here:
    http://www.vintagemachinery.org/pubs/detail.aspx?id=4573
    From the SB How To Run A Metal Shaper:
    francist likes this.
  3. buggsy
    3
    8
    City:
    ashby
    State:
    Massachusetts
    -Return to Top-
    Thank you
  4. CluelessNewB
    346
    83
    City:
    Gorham
    State:
    Maine
    -Return to Top-
  5. Mister Ed
    Mister Ed United States Active User Active Member
    64
    28
    City:
    Fremont
    State:
    Michigan
    -Return to Top-
    At least one of those manuals has a good pic of the oil distribution block and lines (I think its the Army manual). You should always see oil dripping from the two tubes inside. The adjustment is to control the flow to the upper gibs.
    CluelessNewB likes this.
  6. buggsy
    3
    8
    City:
    ashby
    State:
    Massachusetts
    -Return to Top-
    Thanks again for the info. I discovered that the spring was missing in the relief valve. I put one in and I felt like Jed Clampit, oil everywhere. Had to cut down the flow with the adjustment screws. It's all set now.
    Buggsy
Share This Page
