Hope i'm in the correct area to ask this question. on a South Bend 9" model A, Catalog # c1644y, length 3, serial 50036nax10, there is also number B100NKG on the back bed rail. Was told it was made in 1947. It was setting for several years and was used for wood turning. I oiled it up and spindle runs free and easy. The change gears shift free but are stiff running. How do you get to the change gears behind the model label plate to lube the gears. It looks like a lot of work to remove the assembly. Will I have to remove the assembly?
