Can anyone recommend suppliers of ID grinding stones? I'm looking for progressive diameters 0.5" - 1.0", thickness .25-.50", some variety of grit would be nice. Suspect aluminum oxide is fine but maybe something also suited to grinding cast iron too. I see lots of pre-mounted stones in all flavours of grit & shapes with 1/8 or 1/4" shank. Those need to be collet held which doesn't work as well in my application. I'm specifically after the cylindrical donuts for a dedicated tool post grinder arbor.
I keep hearing Norton & Radiac & suspect that's the ones I've inherited. But their industrial websites are a bit brutal to navigate & ultimately I need to buy them onsey-twosey volume from a (assume) machining distributer. Any leads appreciated.
Somebody mentioned these could be water jet from surface grind stones. I don't have any connections in that regard, but does anyone have experience there? From water jet pics they can cut all sorts of rock & marble in this thickness with controlled kerf. But for example would the jetting cutting weaken the stone & be cause for safety concerns?
