Source for (oddball?) flat sprockets?
gr8legs
H-M Supporter-Premium
#1
A couple of years ago I am pretty sure I found some flat chain sprocket blanks without a drilled center hole, just a located center drill point so I could bore out to the shaft size I wanted.
The sprockets I find now all are already center bored for the smallest shaft size the manufacturer thinks is appropriate - in my case I'm looking for a 40-series roller chain sprocket with 15 teeth. They come pre-bored for 1/2" and that's way bigger than I want.
Bushing down is not a great option because my plan is to bore to accommodate threading the center of the sprocket and then securing it to the shaft with a jam nut on each side. Can't really do that if I want a 5/16" shaft and the hole is already 1/2".
Has anyone seen a source for un-bored sprockets or am I imagining that I found them a couple of years ago?
Thanks in advance
Stu
Ulma Doctor
Infinitely Curious
Active Member
#2
Hi Stu,
unfortunately i only see 1/2" bores from my suppliers :(
i suppose you could get a standard 15t #40 sprocket and press fit a slug of cast iron or a steel of choice to a 3/4" or 1" bore #40 sprocket.
bore and face it to length.
you could then indicate, then bore the center to dimension and thread the center accordingly.
it's the next best thing to a fixed bore of the right size.
maybe others may have another suggestion!
all the best :)
DaveInMi
Active Member
Active Member
#3
#40 chain is capable of a lot more torque than a 5/16 shaft can tolerate. What is the application? Maybe there is an other solution that would present less problems. Would machining a hub to fit 5/16 to 1/2 with screws through the flange work?
Tozguy
#4
Sorry don't know a source for such sprockets. I don't know much about your projected application. No offence intended but sometimes when I couldn't find the parts to make something my way its because there is a better way to go about it. How wide is the chain? Do you do any welding?
4gsr
Global Moderator
Staff member
#5
Here's a shaft hub that would probably work. They don't offer one in 5/16" but do have it in metric 8 mm bore but it is out of stock.
https://shop.sdp-si.com/catalog/?brand=sdp&cid=p372
Here's the inch selections that they supply,too. Again, no 5/16 bore
https://shop.sdp-si.com/catalog/?brand=sdp&cid=p932
Edit:
Here's another one that will fit the bill perfectly. You not going to like the price on it!!!
http://www.fennerdrives.com/trantorque/_/Trantorque-Mini-5/16/?s=ZnwyNzI0
I'm sure if you look around and check with a local bearing distributor, you could get it at a much lessor price.
gr8legs
#6
Thanks all for the pointers - apparently I was dreaming when I thought I got un-drilled sprockets two years ago. Or maybe they were bored to 1/2" and I cobbled together what I have now which is rather ugly but functional in a hillbilly way.
The application is a cuckoo clock that the hands are driven by a pair of stepper motors through a 300:1 worm-drive and then a 2:1 chain sprocket drive to the hand shafts.
This current incarnation is a 'get-by' proof of concept. I figure I will use cogged belts in the finished design (quieter) but those pulleys are four times the price of simple chain sprockets and I need to get the design parameters tied down and tested before going that route.
I am getting in to 3D printing very soon and the actual cog belt parts will (I hope) be 3D printed after I crawl up the learning curve.
Stu
tq60
Active Member
Active Member
#8
Make one...
Just get a 1/2 bolt and center drill it with your lathe for the shaft size.
Then drill from side on a flat for a set screw to lock to shaft.
Face of extra material from both head of bolt and nut body of bolt to make a bushing with locking set screw.
If you want to thread to shaft then thread the above assembly.
silence dogood
#9
Go down to your local bicycle shop and ask them for a old used sprocket the size that you want. They will most likely will give it to you free. Use that as a pattern on I seem to remember 3/16" flat stock. Add chain (careful, there are 2 different widths). Almost went that way, turned out that I could bore out the sprocket to fit the hub that I turned (in this case 1")
Silverbullet
Active Member
Active Member
#10
With a rotary table you could mill out the sprocket itself. Even can be done by layout like us old guys use to do. With a couple dowel pins an easy set up to drill the holes to mill the points after .
Ebel440
Active Member
#12
I remember finding a lot of information about making sprockets and timing belt pulleys on bicycle websites many years ago. But don't know what size chain that is. Maybe 20?
chips&more
Active Member
#14
Am I missing something? A bushing will not work? 5/16” will fit into 1/2”? If not, then just make the 1/2” hole bigger. And then Loctite an appropriate bushing. If you are only turning clock hands for a cuckoo clock. Then low torque needs and mischievous accuracy is all you need…Dave
