Sml bench top Chinese lathe BV20-E
BruceFuller
Nov 9, 2013
3
I am looking for a manual for this lathe and the #'s on the end of the ways are 930369. If anyone has any idea of where I can obtain a manual it would be greatly appreciated. Thanx
Sent from my KFTBWI using Tapatalk
I've never heard of this model lathe. The number on the end of the bed is probably the serial number. Try measuring the swing (distance between the center of the spindle and the nearest part of the bed, times 2) and approximate distance between between centers (from the end of the lathe spindle and the end of the tailstock spindle) to the nearest inch, and post these numbers. I or somebody else will then be able to point you to an appropriate manual from Grizzly, Enco, or elsewhere. Nearly identical versions of the same basic models of Chinese lathes are sold by numerous vendors.
This is similar to but probably an updated Harbor Freigjt/Cenyral Machinery 8.5" x 18" sku 31316. It's sparse manual is readily available for download. They sold a similar skunl 41292.
Thought I would add the manual my metric BV20 came with...
  • Lathe BV20 Metric.pdf
