Small Electric Blower
12bolts
Global Moderator
Apr 23, 2011
2,476
I have a 240 VAC low pressure blower that I would like to make infinitely variable speed adjustable. Is this possible with this type of blower? Its 250 mm long with a 200 mm dia fan unit and 100mm dia connections
Last pic shows the label affixed to the outer casing for us plebs to look at........
Cheers Phil
Phil, you might try a fan controller from your local hardware store. The speed control will not be the best, but they do work.
A light dimmer type control or a small variac (50 watts size) would work for that
MS
On second thought- if that is a permanent split cap motor (that 1 uf /400v unit in the photo looks like the run cap) the speed can't be varied much.
MS
