Been looking at Slitting Saw Blades which I have never used before. Part calls for 0.063 wide slot. If using a 0.063 wide Slitting Saw Blade what will be the finished slot width. Guess what am asking what type of tolerance will I be looking at?
If you used a 0.063 wide blade (actual) it cannot cut a 0.063 slot. The blade needs clearance in order to work.
You edited my response? Yes, I am very aware of slitting saws that have a tapered relief towards the center hole. That is why I said “design”. You cannot put a 1/2“ shaft into a 1/2“ hole (maybe with a hammer). You need some clearance. Same story/theory applies to the slitting saw making its slot. The clearance could be in the tenth’s, but is still added to the nominal dimension…DaveGood quality slitting saws have the clearance built in, the faces are slightly concave - well, all my English ones are, dunno about far eastern! The ones I have cut the size they claim pretty consistently. Slow, lots of lube,
Dave H. (the other one)
This would depend on the accuracy of the machine and the arbor holding the saw would it not?Been looking at Slitting Saw Blades which I have never used before. Part calls for 0.063 wide slot. If using a 0.063 wide Slitting Saw Blade what will be the finished slot width. Guess what am asking what type of tolerance will I be looking at?
