    Dismiss Notice
Slight Complication.......Easy Fix
Discussion in 'PRECISION-MATTHEWS' started by MonkMan, Jul 6, 2017.
  1. MonkMan
    MonkMan United States H-M Supporter - Premium Content H-M Supporter-Premium
    81
    28
    City:
    Monkton
    State:
    Maryland
    -Return to Top-
    While installing the coolant system on my PM 1340 GT I found a conflict with the installed DRO reader head support bracket. Because I had ordered the taper attachment, the reader support bracket had to be shifted to the rear somewhat to expose the cross slide for mounting the taper components. The coolant supply pipe location was directly above this point and blocked by this bracket. Two longer socket head screws (M6x1, 45mm long) and two unthreaded spacers (16 mm long) did the trick! It's very tight but everything clears.
    Now I just need to come up with a way to support an hold the two DRO cables and coolant line in place so they don't rub on the tray and backsplash.
  2. RJSakowski
    RJSakowski H-M Supporter - Premium Content H-M Supporter-Premium
    2,606
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
    A neat work-around! To prevent the DRO cables from rubbing on my lathe, I used pulleys. It was tricky finding a pulley that would take the s.s. sheath. Most of the pulleys that I found had 1/4 tracks. I finally found some with 5/16" tracks at a hamfest. I made custom brackets with keepers to prevent the cable from coming off the track. Here is a a photo with one of the OEM pulleys in the foreground.
    On my Tormach, I used a light duty bungee cord to lift the power cable off the tray. It stretches easily and doesn't interfere with motion but provides just enough lift for the cable to clear the tray.
    MozamPete, MonkMan and rrjohnso2000 like this.
  3. MonkMan
    81
    28
    City:
    Monkton
    State:
    Maryland
    -Return to Top-
    Clever. Thanks RJ
Share This Page
