I have a 14" sidney lathe, I am trying to use the taper attachment for the first time. when it is all hooked up and you start traversing it goes a few inches then binds up. I am not sure but I think it has something to do with the cross slide binding. I went through the manual and it shows which nuts to loosen to adjust it and what not but does not say anything else. Does anyone have any info on this? I was thinking about just unbolting the crossslide handle and seeing if it works then.
