Shop Made Hold Downs And Clamps
jpfabricator
Sep 19, 2012
3,063
Ok... let's see your shop made hold downs and clamps! Anything you made special for a specific job to everyday clamps. From fit and pretty to quick and ugly, don't be shy!
Sent from somwhere in east Texas by Jake!
Here's one that came with the K&T.
OK, I'll bite :grin:
MDF ''step-clamps'' to hold a piece of plywood in place.
How to hold a glass bottle on a mill
A quick clamp to re-work a part, made out of a drop.
Holding a UHMW cylinder in the vice
When I needed to mill a spline in a shaft I made a quick dead centre from a piece of angle iron with a slotted hole and a bolt with the end turned done to a 60deg point.
I also locktighted a drilled out nut to the shaft for indexing of the 6 splines as I rotated the shaft. Worked surprisingly well.
I don't have one yet, but once my CNC mill/router is up I will have to make one for the electronics encloses I use for my products which will have 8 screws holding the front and back of the chassis to a piece of plate bolted to the table.
Currently I hand mill everything but demand is catching up to the speed at which I can produce. For me it won't be a choice but a need. I'm glad it's going that direction and not the other.
Thanks for the look at holding UHMW cylinders. I am working on a logic probe to be made of a similar material.
I believe this is the manure bucket bracket from a small barn trolley system.
Well, at least it was in the pile of rusting parts from that system.
Regardless, plan is to fit T nuts and threaded rod to make a large C clamp for weldments.
She has a 1/2inch slot between the two pieces of flat bar which comprise the shell.
I figure that I can make and place multiple thread mechanisms.
Problem is that I haven't needed it since I found her!
Daryl
MN
Here's some little jack screw clamps I made for the Taig. Unfortunately I don't have photos of making the slots.
Setup using a piece of steel strap to lift up from the table:
Milling the sides made a lot of nasty needle-like swarf:
The nuts ensure that the screws don't botton out in the t-nuts:
Size was a bit off:
Checking the alignment of the packing, not quite right:
Ah, much better:
And the finished product:
