    Dismiss Notice
Sherline, threaded blank
Discussion in 'SHERLINE, TAIG, TITAN & SIEG MINI-MACHINES' started by kvt, Jan 11, 2015.
  1. kvt
    kvt Active User Active Member
    516
    113
    City:
    San Antonio
    State:
    Texas
    -Return to Top-
    Does anyone know where a person could get a threaded blank about 3 to 4 inch in diam, prefer Alum
    have a couple of projects, Like making a custom holder and a custom cutter, but want to start with a blank made to fit on a Sherline spindle. Have seen some used for various stuff on YouTube but do not know where to find them. Did find End Mill blanks by A2Z but nothing bigger.
    here is one of the projects I want to do.
    https://www.youtube.com/watch?v=ZN1uVDVo5fg,
    KVT
  2. ogberi
    ogberi Active User Active Member
    397
    63
    Probably not in my shop
    City:
    Homosassa
    State:
    Florida
    -Return to Top-
    I ended up purchasing a 3/4x16 tap and die at a local Ace hardware, about $30 for the pair. Dead useful when I want to make an arbor or special tool. Just keep in mind that either one takes a bit of "oomph" to turn when threading. Use plenty of Tap magic.
  3. rwm
    rwm Active User H-M Supporter-Premium
    1,004
    113
    City:
    Charlotte
    State:
    North Carolina
    -Return to Top-
    [SUB]I have a better idea.
    Do you have a 3 jaw chuck that fits on the mill? If so, use it as the tool holder. Drill a hole obliquely in a piece of 3/4" rod and put a 1/4" lathe tool through it. Hold it in place with a set screw and you have a fly cutter. Works great!
    [/SUB] 15%2B-%2B2.jpg
    [SUB]
    Is that what you meant?
    R[/SUB]
  4. mikey
    mikey Active User H-M Supporter-Premium
    1,745
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    As far as I know, nobody makes these for a Sherline spindle. They are simple to make but you'll need a bigger lathe to do it with. If you make a drawing of the plate, complete with spindle register recess, I don't think a shop would charge you too much to make a few up. At least you can get on with your projects.
  5. MarkStephen
    MarkStephen United States Active User Active Member
    19
    18
    City:
    The Plains
    State:
    Ohio
    -Return to Top-
    I made this flycutter on my Taig lathe with the milling attachment and some creative clamping. turned out pretty good and was the first "real" project I made with the lathe. I used one of the Taig blank arbors I picked up from Nick over at http://www.cartertools.com/. Already threaded 3/4-16 so that hassle is out of the way. Catalog # 1132
    Never mind the drawing, it's for my next project. :shush:
    Cutter is on a 20* angle.
    Mark
  6. pjf134
    pjf134 United States Active User Active Member
    11
    38
    City:
    Bridgeville
    State:
    Pennsylvania
    -Return to Top-
    If making a fly cutter is what you want, here is the one I made on a Sherline Mill. I used 10 deg. on slot and works great. I used a Sherline lathe for the 3/8 dia. to fit the mill holder.
    Paul
  7. darkzero
    darkzero Global Moderator Staff Member H-M Supporter-Premium
    1,078
    113
    USA
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    Would a faceplate work for you (it does have some predilled holes)? Chuck adapters could also be used but they are usually cast iron & have pre drilled holes also. Not sure if these have a register though or one that matches (I'm assuming the Sherline has one)
    3" alum faceplate
    http://www.pennstateind.com/store/CF3.html
    4" steel faceplate
    http://www.pennstateind.com/store/CF4.html
    4" cast iron faceplate
    http://www.amazon.com/Grizzly-H3412-Cast-Faceplate-4-Inch/dp/B0000DD5B7/ref=pd_bxgy_hi_text_y
    As said, they'd be pretty easy to make with a bigger lathe. I'm sure there are plenty of guys here who could make you some if you ask.
  8. rwm
    1,004
    113
    City:
    Charlotte
    State:
    North Carolina
    -Return to Top-
    Elegant!
    R
  9. MarkStephen
    19
    18
    City:
    The Plains
    State:
    Ohio
    -Return to Top-
    Thanks rwm, those blank arbors are real handy. I have also made a saw arbor that will hold 1 or up to 4 saw blades for cutting different width slits/slots and I have one more blank on hand and I'm trying to decide just what to do with it. Maybe a mini boring head?
    At less than $3.00 a pop and already threaded and dimensioned for the spindle, they are mighty handy.
    Mark
  10. ogberi
    397
    63
    City:
    Homosassa
    State:
    Florida
    -Return to Top-
    Absolutely! I just bought 10 of them, arceady made a flycutter and a drillbit holder. Needed the clearance a chuck couldn't provide to drill a part for a neighbor. Those arbors are great, and I couldn't make them that cheap. Really repeatable too.
  11. kvt
    516
    113
    City:
    San Antonio
    State:
    Texas
    -Return to Top-
    Thanks for all the info everyone. Question, The blanks are for Taig, but will work on the Sherline. Do we have to do anything special to them to get them setup.
    KVT.
  12. itsme_Bernie
    itsme_Bernie United States Active User Active Member
    69
    48
    City:
    NNJ
    State:
    New Jersey
    -Return to Top-
    Setup to fit the Sherline spindle? I don't know the dimensions of a Taig spindle.
    I remember buying two 3 inch "blanks" for my SHERLINE with the 3/4-16 already tapped into it. I remember it being a Sherline accessory.
    Bernie
  13. MarkStephen
    19
    18
    City:
    The Plains
    State:
    Ohio
    -Return to Top-
    I'm pretty sure they will work without problems. I have seen more than a few interchange chucks / faceplates ER collet chucks, etc.. Grab up one and give it a try. Little to lose, more than a little to gain.
    Mark
  14. kvt
    516
    113
    City:
    San Antonio
    State:
    Texas
    -Return to Top-
    roger that, I prob will order one and see what it is like. What is the worst, Machine it into something else.:rubbinghands:
    KVT
  15. MarkStephen
    19
    18
    City:
    The Plains
    State:
    Ohio
    -Return to Top-
    Now that's the spirit ALL us home shop folks need to have! :))
Share This Page
