    Dismiss Notice
Setup Blocks ("1-2-3 Blocks")
Discussion in 'METROLOGY - MEASURE, SETUP & FIT' started by Uglydog, Jul 10, 2017.
  1. Uglydog
    Uglydog United States Active User H-M Supporter-Premium
    1,156
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    francist, higgite, brino and 3 others like this.
  2. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    3,800
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Multiples of each! 123 blocks with multiple holes can be versatile, but in practice, the holes collect swarf that gets into the setup and ruins the accuracy and rigidity, and on many of the store bought ones the threads are distorted from the heat treating process (or just poor work) so bolts do not screw into the threads. For many uses I like the ones with no holes, but for some unknown silliness, they actually cost more! Huh? How do they justify that? Proper 123 blocks need to be hardened and ground to within a few tenths or better for accurate setups and metrology use, with all faces precisely 90 degrees to each other, and that is not particularly easy to do. Matched sets also need to be truly matched.
    For ordinary work with setups on the mill, the imports are a bargain. They are usually amazingly accurate for the prices, but do need to be vetted, always. Stan Zinkosky is really good at testing them and truing them up for service in his shop:
    https://www.youtube.com/user/shadonhkw/search?query=123+blocks
    I want to find a decent deal on some good 246 blocks...
  3. mark_f
    mark_f Global Moderator Staff Member H-M Supporter-Premium
    2,117
    113
    City:
    Mercer
    State:
    Pennsylvania
    -Return to Top-
    That is a very interesting article. I get the impression from the article that the 1 2 3 blocks are a recent invention to the machine shop industry. The first time I remember being exposed to the 1 2 3 block was while working in a Texas machine shop where every machinist had a set in his tool box. We used them routinely in setups on machines like the Bridgeport. This was in the late 1970's and early 1980's. That was my introduction to them. They were common earlier than that. I know most were made by Mitutoyo and readily available from the tool supply houses that supplied the shops. There was also a set that was 2 4 6 blocks.
    4gsr likes this.
  4. Buffalo20
    Buffalo20 United States Active Member Active Member
    278
    63
    City:
    Camden
    State:
    New York
    -Return to Top-
    I have 3 cheap sets, a Fowler set and a B&S set, Bob's comment make made me think, the B&S set is the only one, when the threaded holes are messed up
  5. rgray
    rgray Active User H-M Supporter-Premium
    324
    83
    City:
    Helena
    State:
    Montana
    -Return to Top-
    Interesting write up. I liked it. Especially the Moore influence to those blocks.
    On mine I never seem to need holes.
    If left without holes they aren't as recognizable as a tool and you'd have to guard them to keep someone from using them as a nice piece of scrap iron, or anvil or ???
    brino likes this.
  6. Dave Paine
    Dave Paine United States Active Member Active Member
    187
    43
    City:
    Eastern PA
    State:
    Pennsylvania
    -Return to Top-
    Interesting article. Thanks for sharing.
    I would not have expected to find so much details and options on such a simple tool.
    I have a cheap 1-2-3 set from perhaps CDCO. So far I have not needed to use the holes mostly due to the holes and threads being smaller than the diameter and threads on my clamping set for the mill. If you do add holes, make the size and thread to be the same as your clamping studs.
  7. Bob Korves
    3,800
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    If you add threaded holes, make the threads oversized (loose fit.) If the blocks are properly heat treated, there is a good chance of the threads (and the blocks) distorting during the hardening process. After the blocks are hardened, the only real way to repair the threads is to thread grind them, not something many hobby machinists are set up for.
Share This Page
