- Mar 21, 2013
- 4,059
I'm just being anal probably. I would like this thing to last longer than I do and if the oiling system is installed correctly I would like to believe that it would be better than squirting oil on the ways like I do now.
Yea, I figured this out when installing the same DRO on my PM25. But fortunately all of the scales for that system came with backing plates. For the one I ordered for the 12Z, only the 350mm came with a backing plate (for Y axis). The other two: the 600mm and 700mm came without backing plates. After doing a quick visual, i.e. held the scales up to the machine, I quickly realized that I need to order some aluminum flats to use as backing plates or risk damaging the scales. Thanks for the heads up.
