Selecting A Power Relay Rc Arc Snubber
countryguy
May 7, 2014
776
image.jpg image.jpg Snubber? Now that is a cool tech word! The thermolyne muffle furnace/oven is done and running. I used a cool power contractor from the original gear Rather than SSRs. It does sound cool with all the snapping noise. But the noise has bounced the rs485 comms at times. It cannot be good for thee PID controller when that field collapses. Does anyone recall what the formula is for an AC snubber ? 120vac coil. Passing two legs for a totally of 24 amps thru the contacts. No more than an amp on the coil I would say.
Digikey has these:
http://www.digikey.com/product-highlights/us/en/cornell-dubilier-quencharc-caps/744
Any help appreciated! Cannot wait to get some metal in this thing!
One of the beauties of RS485 is that it's differential, a balanced two-wire system that should mean that coupled noise is "common mode" and appears equally on both wires, and so would get cancelled out at the receiver. Is your system two wire?
-brino
No question I need to do some clean-up as I simply wanted to "fire it up!" I need to setup a ground point for the shielded braid on the 485 and the USB/485 comms. It's quite possible that I'm taking a hit anywhere in the AutomationDirect equipment path to power. PID controller, Comms, to converter, USB to the free SOLO freeware app that locks up often!
I took 1 leg from the 220Vac and used it to power the PID. I'll pull apart the surge protector! Love free! Good call JD .
The circuit write up was well written! I enjoyed the review of the material for a snubber! Thanks Tony.
Brino- Agreed - Should hold out to various noise - It's sporadic and possibly due to other causes. Thanks for the post!
