McMaster Carr carries 1/8 by 5/8 bar stock in both low carbon steel and stainless. I placed an order for both today. When polished, stainless looks a lot like vintage chrome or nickel plating. Finding a plating company for small jobs has always been a challenge, so I may use stainless.
Options for the rounded ends:
1) At the shop, someone suggested that I use the Tormach to cut the rounded ends on the bar stock. The idea was to cut each piece slightly larger than the finished length (approximately 4 inches), then punch the holes. Several pieces of bar stock would then be bolted to a jig. Thereafter, the rounded ends would be cut on the Tormach. I am concerned about lining everything up repeatedly and about punching the holes before bending. The hole spacing needs to be relatively precise and the holes need to be round.
2) The shop has a Jet 20 inch 2 HP disc grinder which sands bar stock very quickly! It took literally seconds to freehand each rounded end on this piece.I am considering making some sort of jig that could be mounted to the disc grinder table to 'swing' the bar stock back and forth at the required diameter. Link to Jet Disc Grinder:
https://www.jettoolstore.com/collec.../jet-577010-j-4421-2-20-220v-disc-sander-3-ph
3) I also have access to a Jet mill and found this video....
4) I have considered but rejected the water jet, primarily because my original piece was likely made from bar stock. I'm not sure it can be seen in the pictures, but the edges are rounded along the length, so I'm guessing guessing it started as bar stock.
5) Impossible to tell from the pictures, but it appears that just the rounded ends were sheared off. Does anyone make a metal punch/shear that would only cut the rounded ends from my bar stock?
Thanks for all of the replies thus far and any additional thoughts. This forum is great!
Jim
