- Nov 14, 2014
- 851
Hi all,
I am asking for help figuring out why my new to me 1985 Southbend Fourteen can't hold decent tolerance on the X axis when making finishing cuts. E.g. Reducing diameter of work Parallel to the spindle axis.
Spent the day making mucho test cuts. Short of it is:
- dial in .020" depth of cut on the crossslide, the lathe cuts .024"
- dial in .010" depth of cut on the cross slide, lathe cuts anywhere from .014" to .019"
- dial in .005" depth of cut, lathe cuts .008" up to .015".
It seems to cut .004" to .006" over my selected depth consistently, with smaller cuts showing greater variation. Sometimes twice what I dial in. My goals is to consistently hold a thou when reducing diameter of work. This is very frustrating as I don't see any obvious movement or deflection in the tool post or cross slide when making the cut. I dial in the selected depth of cut. At the end, the tool bit is deeper than it should be.
All of this even with the gibs tightened up and the cross slide locked down to the taper attachment to prevent movement. Work supported by the tailstock. And also making a variety of test cuts with both HSS and brazed Carbide tooling.
This looked like a nice tight machine. Good original paint. Gears show little wear. Bed is near perfect. The tool post is a stout QCTP. The spindle has around .001" of play, maybe a bit less.
I could understand dialing in a cut, and coming up oversize due to tool pressure. But consistently and widely over the dialed in amount has me baffled.
What could I look at to tighten this thing up? Iam sort of stumped.
Thanks much for,any suggestions anyone could offer.
Glenn
Glenn
