  • NOTICE: There are two new video channel areas set up, one for staff, and one for subscribing members. You need to create a folder. Then add your media to that folder. Once added, you can cut and paste the code at the bottom right to embed the media into a post on the forum.
    It works very similarly to YouTube, except videos are stored on our server. Click Here For The Video Channels
[4]
Sandpaper finish vs ways wear. Ultimate solution.
[3]
[10] Like what you see?
magicniner
Active Member
Active Member
Oct 21, 2017
63
Likes
45
#4
Laugh, I nearly did!
This is "Sandpaper vs. Ways Ultimate Solution" in my workshop, the concertina bellows overhangs the ways by 2" front and rear and can be brushed and vacuumed clean after dirty jobs whilst the ways stay perfectly clean and liberally oiled.
I use a variety of milling and grinding units on the lathe and the bellows catches all the debris. the front clips in place, the rear is held by one screw, that's "Sandpaper vs. Ways Ultimate Solution" :D
Wireaddict
Active Member
Oct 24, 2013
136
Likes
40
#5
In the video, I would've made the divot in a block of wood or scrap metal rather than my D/P table; still a good way to get the job done, though.
samthedog
Active Member
Nov 21, 2012
764
Likes
272
#6
Maybe I'm new to all this but didn't he just destroy the bearing he was going to use by having all the grit fall down into it while he was sanding?? I mean it's not even a sealed bearing. I certainly wouldn't want to put that thing into an engine afterwards - especially since it is holding the crankshaft.
Paul.
[6]
[5] [7]
