  2. We want to wish everyone a healthy, happy New Year, full of joy and success. God bless you, and thank you for supporting The Hobby-Machinist.
    Dismiss Notice
rung fu clone RF-45 ZX45 cnc conversion
Discussion in 'MACHINE BUILD LOGS' started by jumps4, Aug 22, 2012.
  1. jumps4
    jumps4 Global Moderator Staff Member Active Member
    177
    63
    City:
    New Port Richey
    State:
    Florida
    it got the face and down the side about .050 it is grinding now. everything is working perfect.
    i had to write the code by hand there is no wizard i know of for this.
    steve
  2. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    I turned the arbour to grind it and it pulls the shell mill down and centered as the collet tightens into the rotary table center and pulls in.
    steve
  3. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    First testing of my grinder on the mill
    I finished the g-code and reground the shell mill. everything went perfect and the shell mill and diamond wheel survived.
    it took twenty runnings of the program to get below the damage. that will teach me to read what i type before hitting enter. the angles where supposed to be 5 degrees and .5 degrees and i got pretty close.
    steve
    [video=youtube;AkaZsziX5JU]http://www.youtube.com/watch?v=AkaZsziX5JU&feature=youtu.be[/video]
  4. Blackhawk
    Blackhawk United States Active User Active Member
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    image.jpg Got my electronics, did not have any paperwork for wiring. I looked at your pics and can't figure it out. I want to see if all works well before I leave feedback to vendor just in case something is broke. Is there a place online that has wiring info on this
    rob
  5. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
  6. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    I think i am getting close with the two smaller motors but my wire colors are red, yellow, blue and green. I am assuming yellow will be black? I may have to hold off on the 4200 stepper because i am missing the terminal to hook it up. The pic is what is missing.
  7. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    the wire colors and locations are normally in the description in the ebay add. try looking there
    if not google the part number on the motor and go to pics you should find it
    steve
  8. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    found and wired stepers, check voltage on power supply (61) powered C10 breakout board powered up power supply and nothing caught on fire. Now im guessing i need to start mach3 and configure it?
  9. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    Steve,
    I setup mach three same as the X2 and no joy, I think because my system is same as yours on the 45 you built, i will play with it more to see what i can get going.
    rob
  10. cjsamples
    cjsamples United States Active User Active Member
    5
    18
    City:
    Hiram
    State:
    Georgia
  11. cjsamples
    5
    18
    City:
    Hiram
    State:
    Georgia
    This website has a few videos setting up the electronics as well. He is using the C10 board. Well worth the watch as I followed along with him and learned alot.
    http://buildyourcnc.com/CNCElectronicsandWiring.aspx
    He goes into checking things with a meter so you don't let the smoke out.
    Chris
  12. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    rob
    did you reboot the pc after installing mach3 everyone including me forgets to reboot.
    x step pin 2
    x dir pin 3
    y step pin 4
    y dir pin 5
    z step pin 6
    z dir pin 7
    all enables to pin 17
    for the black controllers, all commons ( connectors that say + ) are 5v positive just jumper across, three small jumpers on the controller then one wire back to common terminal or 5v positive if thats what your breakout board has.
    you should start a thread and post better pics of the controller terminals so i know what i'm helping you wire. the big controller is different but most of the extra wire terminals you wont be using on it. but the pic is fuzzy
    steve
  13. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    if you need them i will take pics of my mach3 settings for the zx45 and post them for you
    steve
  14. OakRidgeGuy
    OakRidgeGuy Active User Active Member
    1
    38
    City:
    Oak Ridge
    State:
    Tennessee
    Steve,
    Just wanted to let you know that I had to reload D2nc to get the screen sets to load to Mach3.. it works now..
  15. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    kewl
    listen if you post in your build thread i will see it i get emails for every thread i reply in. that way everything pretaining to each persons build stays all in one place and makes it easier for others to follow.
    play with the dxf part of d2nc that is what you want to learn first.
    steve
  16. GaryK
    GaryK In Memory Rest In Peace
    2
    38
    City:
    Tyler
    State:
    Texas
    That is truly a great job you did on this machine!
    Gary
  17. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    thank you gary I use the mill daily and there have been no problems
    sometime after the first of the year I will take it all back apart for cleaning and inspection readjust and lube everything. It should be broke in by then and need a good cleaning from everything seating into place.
    steve
  18. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    Steve,
    What was the thickness of the aluminum you used for your motor mounts?
    lanham
  19. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    it was 1/2" thick
    steve
  20. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    Thanks,
    I will try to mill a few monts today if i can figure out the drawings demensions.
    lanham
  21. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    what dimensions are you looking for?
    steve
  22. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    here are all the drawings i have, there may be a few in here that are not from the mill i grabbed everything
    i also didnt name things very well lol
    steve
  23. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    my cnc capability is limited to a zen toolworks cnc so i have to do all the work manually. I tried opening your dxf files im emachine and draftsite but cant get dxf to 0 so i can figure out demensions so i will print out each drawing and see if i can figure out coordinates.
  24. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    select a part of the drawing in emachineshop and look up at the top it will show the size of what you selected.
    or select the entire drawing and on the upper left type in the cordinates as 0, 0
    steve
  25. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    my drawings are not a set of plans and should be checked to what you are building. most drawings were done on the fly as needed and there may be modified drawings of the same part. sorry they were not planned out better but i never concidered someone making a copy of my mill.
    I hope they are helpful
    steve
  26. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    Steve,
    thanks on the tip on changing the zero, helped my brain get it. Here is what i came up with.
    Looks like i will be using my new rotary table to cut the holes, i will also post this on my build page. copycat mill
    lanham
  27. Blackhawk
    9
    18
    City:
    Fredericksburg
    State:
    Virginia
    Do you think that HF double cutting saw will cut .5 aluminum?
  28. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    yes it will cut 1/2" aluminum no problem
    steve
  29. jumps4
    177
    63
    City:
    New Port Richey
    State:
    Florida
    this is a video of the z axis after calibrating and setting backlash compensation. the movements are in .0001 increments reversing the direction.
    this impressed me concidering this head weighs 300lb and i bought the cheapest parts i could afford for this build.
    steve
    [video=youtube;7wtMc__ez7M]http://www.youtube.com/watch?v=7wtMc__ez7M[/video]
    I know i have a funny voice!
  30. harmsdesign
    harmsdesign Iron Registered Member
    0
    1
    City:
    Burbank
    State:
    California
    Very inspirational thread. I am planning a conversion of my RF31, and have been slowly gathering parts. I have my electronics mostly sourced and partially operational. My biggest challenge is taking apart my mill to spec ballscrews and generally survey the heck out of it, then reassembling it to build its own parts.
    Thank you for sharing your conversion.
Share This Page
