    Dismiss Notice
rung fu clone RF-45 ZX45 cnc conversion
Discussion in 'MACHINE BUILD LOGS' started by jumps4, Aug 22, 2012.
  1. jumps4
    jumps4 Global Moderator Staff Member Active Member
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    Re: zx45 milling machine cnc conversion
    I have drawn the x axis ballscrew bearing mount end plates and motor mount plate. I'll do the g-code tomorrow and start milling them out. It is so nice to have the sherline cnc to cut out these parts or this would be taking me months.
    steve
  2. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    the sherline cut out the brackets to hold the bearing mounts on the ends of the x axis turned out perfect the original alignment pins fit right in. the ballscrew on the other hand was a problem. i tried to use my new lathe to grind the end down to fit the end bearing after cutting the ballscrew to length and it was a dumb mistake, way out of round. I chucked it in my old 9x20 hf with the collet chuck mounted, then used my homemade toolpost grinder and i ground it back round and undersize, then i made a sleeve pressed it on the end and reground to size. this time all mounted and preloaded there is less than .0005 wobble, phewwww i'll post pics of the fix tomorrow.
    steve
    DSCF0227.JPG DSCF0228.JPG DSCF0229.JPG DSCF0230.JPG DSCF0231.JPG DSCF0232.JPG
  3. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    I forgot to mention that by reducing the end bracket height so it does not hit the saddle i gained 10" of extra travel. I'm not going to use all of it because of the overhang but a little extra is nice. the stepper motor mount will limit the extra I can use but thats about 3" extra on each end. i'll stop it with the limit switches.
    steve
  4. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    I made the ballnut mount and installed everything on the x axis, there was a slight binding at the motor end of travel so i took it all back apart and remeasured everything. the chinese must have drilled the alignment pin holes in the table after assembly because the motor end bracket was .005 higher than the other end. the pins removed and the ends matched. then i rechecked the height of the ballnut mount and found it was .024 to tall. i removed .024 from underside of the table mounting spot and everything is very smooth now. the sleeve and regrinding of the ballscrew end worked out good the collet chuck straightened it out. after running the table with a drill i noticed the couplings do not clamp the screw tight enough the way they were designed so i'm going to grind flats on the shafts and add set screws to the couplings. there is still no new motor from china for the z axis aarrrrgggg
    DSCF0233.JPG DSCF0234.JPG DSCF0235.JPG DSCF0236.JPG DSCF0237.JPG DSCF0238.JPG
  5. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    I only spent about an hour in the shop today i needed to rest but i did get the front and back panels cut out of my enclosure and the electronics mounted. man am i glad i prewired, I would have never been able to wire this in the enclosure. I powered it up and everything seems still intact. I still havent wired and tested motors yet. fans are a little loud but really moving a lot of air and i put in the air filter in the bottom. I also put all the screws in the panels i took the pic too soon.
    steve
    DSCF0240.JPG DSCF0241.JPG DSCF0242.JPG DSCF0243.JPG DSCF0244.JPG DSCF0245.JPG DSCF0246.JPG DSCF0247.JPG
  6. Old Iron
    Old Iron United States Active User H-M Supporter-Premium
    27
    48
    City:
    Andalusia
    State:
    Alabama
    -Return to Top-
    Looking good Steve, That is way be on my little pea brain.:rofl:
    Paul
  7. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    thanks paul
    I am trying to take my time and do it once.
    notice the enclosure i used? It is one half of the lathe stand i got with my new lathe. this is a better use for it than holding up a lathe. I'm going to use the other half as a tool grinder stand and bolt it down.
    steve
  8. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    at 2:00am my back decided it didnt want me to lay down pill or no pill, so i went out to the shop to work on the y axis.
    this tree frog was waiting for me when i started to put the camera on the tripod so i took his pic. I really pushed the sherline on this piece it was cutting at 5.11 ipm with a 3/16 2 flute hss 3500rpm at a depth of .025 and finished the part in 1 hour and 5 minutes. I'll make the motor mounts and ballnut mount tomorrow . I contacted the company in china today by email and they said they would call the post office about my motor and let me know where it is ??? it has been a month i think it's still on their shelf and they are feeding me eggfooyoung. I may have to use the beat up z motor. it's might be ok once i fix the broken wire but i didnt want to mess with it if they wanted the old one back...
    DSCF0249.JPG DSCF0251.JPG DSCF0252.JPG DSCF0253.JPG DSCF0255.JPG DSCF0256.JPG DSCF0257.JPG DSCF0258.JPG
  9. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    today went ok untill the end I made the rest of the y axis motor mounts parts they just need 8 holes drilled and tapped then installed that came out fine. i made the spacers for the x axis motor mount and they just need drilled and tapped. then i decided to let the mill cut out the x axis motor mount plate and either windows or mach3 got a headache so the last pic is scrap metal my sherline made me. everything was fine all that was left for the program to finish was drill 4 holes for the motor bolts and cut the part out. mach3 did not switch to a slow speed to drill. it plunged in to full depth and a G0 plunge then tried to move to the next hole while still down. I stopped everything reset the mill to zero, checked the g-code and began again making the holes larger to use a through bolt and nut instead of tapping a hole it could be salvaged and the first one went fine the second hole was no where near where it was supposed to be. scrap metal! I flipped the breaker and went in the house tomorrow is another day.
    that is the last part i needed to mount the motors:lmao::lmao::lmao:. i would have thought it was the sherline messing up but it does not speed up when it is acting up it just misses steps. i never had it do this before and i better find out why before i start running the new mill ( it wont be on that pc for sure )
    steve
    DSCF0258.JPG DSCF0259.JPG DSCF0260.JPG DSCF0261.JPG DSCF0262.JPG DSCF0263.JPG DSCF0264.JPG DSCF0265.JPG DSCF0266.JPG
  10. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    everything that went wrong yesterday was my fault i was too tired to be in the shop after no sleep the night before. there was nothing wrong with windows, mach3 or the sherline, i set it up wrong and the recentered on the big cut out and not the center of the part duhhh
    today almost started the same as the power went out while running but i reset everything and completed the parts i needed to install all 3 axis. i just need to make covers to keep swarf out. tomorrow i'll install and adjust everything. the lift cylinders came today and next i will start work on the limit switches and brackets for the cylinders.
    steve
    DSCF0267.JPG DSCF0268.JPG DSCF0269.JPG DSCF0270.JPG DSCF0271.JPG DSCF0272.JPG DSCF0275.JPG DSCF0276.JPG
  11. hq308
    hq308 Australia Active User Active Member
    0
    16
    City:
    Sydney
    -Return to Top-
    Nice work Steve, keep the updates coming!
  12. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    I put all the parts together and the X and Y axis are completed and work smooth with no backlash if i try to turn the screw at all the table moves, reversing direction is instant movement no free movement ( I wonder if i should leave a tiny bit like the sherline for heating up, I probably will for break in. and use mach3 backlash compensation) Z axis is still waiting for a motor but everything is made and ready for install and final adjustment. right now I could hook the motors up and run the mill but i'm not going to yet. I want to finish it first I know me I'd start using it and that would be it. I want to design a limit switch system that is adjustable so that before running the program i can set stops into the machine that make it almost impossible to hit the table, vise, or anything unplanned making them more useful than just the end of travel. I also want to design and build the enclosure and a flood cooling system.
    steve
  13. MGP
    MGP United States Active User Active Member
    2
    18
    City:
    WOODBURY
    State:
    Connecticut
    -Return to Top-
    Looking Good Steve!!!!
  14. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    thanks mike
    all i did today is clean adjust assemble and make sure every bolt is tight it is 12 wire connections away from starting to move on it's own. I moved it out of the middle of the floor and i need to clean up my mess. It is not leaning my tripod is tilted
    steve
  15. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    ITS ALIVE!!!!
    boy do i have to do something about the mill stand vibration this noise will drive me nuts
    i wired the motors and tested everything today. i have not calibrated anything yet but it is close
    the max ipm right now is set to 50 to keep things safe
    here is a video excuse the noise and ugly old man
    steve[video=youtube;3PXo4sqKEyY]http://www.youtube.com/watch?v=3PXo4sqKEyY[/video]
  16. 7HC
    7HC Active User Active Member
    5
    38
    City:
    Tampa
    State:
    Florida
    -Return to Top-
    Seems to be the short travel (in and out from the column) that's causing the problem.
    Side to side sounded fine as did the Z.
    I know you'll have the issue figured out by the time you read this though. :)
    M
  17. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    there is nothing wrong with the mill it is the flimsy base cabinet sides vibrating and making all the noise the motors do humm but the cabinet is just amping the noise up
    steve
  18. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    I'm going to go check the gib adjustment and hang the head maybe some more weight will shut up the base
    steve
  19. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    I really didnt go into all the settings and wiring in this thread because everything is basically the same as the other cnc i helped MGP just build
    the parts are the same wiring and the same breakout board so the pin settings are the same also
    the ballscrews are the same pitch
    so everything is in this other thread if your wanting the setup and wiring
    http://www.hobby-machinist.com/showthread.php/6680-X2-Mini-Mill-CNC-Conversion
    the only differences are the 110v circuits for 4 power supplies and the solidstate relay circuit
    steve
  20. 7HC
    5
    38
    City:
    Tampa
    State:
    Florida
    -Return to Top-
    In that case maybe just slap a sound deadening pad on the inside of each wall of the cabinet?
    They're commonly used on the inside of auto body panels. You don't need the expensive stuff used for optimizing sound systems, just the heavy asphalt ones with self adhesive backing. Most paint and body supply places carry them.
    Another way would be to tack a length of angle iron to the inside of each wall, which would change the frequency at which it resonates.
    M
  21. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    thats a good idea M
    thanks
    steve
  22. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    I have the mill tuned and calibrated ready to make swarf
    the cabinet still rattles but the mill is smooth and dead on
    it is running a 26" x 9" route at 18 ipm in the video
    z axis needs nothing the motor makes no difference running up as it does down and tuned in perfect so i dont need the lift cylinders as per my original plan for the 4200 motor it doesnt even notice the weight of the head.
    tomorrow I will make something for the first time and measure it after.
    now i need to buy a finger brake and shear and start on the enclosure
    steve
    [video=youtube;0QVDDqW-O8M]http://www.youtube.com/watch?v=0QVDDqW-O8M[/video]
  23. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    thanks shawn i have been planing this build for years
    steve
  24. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    run a first test cut today on a 1" circle and it was .001 out of round i thought i was all set until i checked repeatability in 20" and I'm loosing steps i lost .045 in 20" on average
    I tried recalibrating same thing on long runs
    I moved mach3 up from 25khz to 35khz and got an improvement, same old problem windows operating system and mach3 not playing well together.
    I ordered a UC100 usb controller from cnc4pc ($110.00) to boost my khz from 35 to 100 and then increase my steps per to 20,000
    I had planned on a smooth stepper in my original parts list and decided to try it without one. it didnt work good enough, now i'm opting for the uc100 because it is a direct plug in to my breakout board and uses usb for com.
    time for the mills first oil change
    steve
  25. 7HC
    5
    38
    City:
    Tampa
    State:
    Florida
    -Return to Top-
    Just looked that one up, they certainly pack a lot into a simple DSUB25 shell!
    I like the fact that it takes a lot of the load from the computer CPU, so allowing the use of a lower spec computer than would be usual.
    You could justify the price on that alone.
    M
  26. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    7hc
    plus the fact i dont have to rewire my panel to use the uc100 it just plugs in to parallel port on the controller and a usb in to it.
    made a few small parts for a mercury outboard on it today it is dead on on small moves it looses track on long transitions it's in full use now.
    i need to get some sheet metal and design an enclosure.
    steve
  27. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    Today went really well a little more tuning while i'm waiting for the new controller and i milled a 1" circle in hot rolled steel for the first time today. it went great I have never had a mill to cut steel like this. i set the machine to 1.9 ipm and a per pass depth of .030 it took 46 minutes to reach a depth of .5 with a $2.00 reground hss endmill i got off ebay. the finish is really smooth and the final piece was 1.001 on x axis and 1.000 on y, it is getting better all the time for accuracy. when It first finished i touched the part and endmill and they were not even warm.
    here is a video and a couple pics.
    now I have to learn how to mill steel i have never had a mill that would do it before.
    steve[video=youtube;0vY1EVfDdNE]http://www.youtube.com/watch?v=0vY1EVfDdNE&feature=youtu.be[/video]
  28. Old Iron
    27
    48
    City:
    Andalusia
    State:
    Alabama
    -Return to Top-
    Its really doing a good job eating the hot roll steel, I bet your really happy today I'm glad things worked out for you.
    Paul
  29. jumps4
    179
    63
    City:
    New Port Richey
    State:
    Florida
    -Return to Top-
    I am but now i have to start a thread to ask a bunch of questions on milling steel I'm new to this my other mills just would not do it well.
    steve
  30. DaveSohlstrom
    DaveSohlstrom United States Good bye Active Member
    6
    18
    City:
    never never land
    State:
    Yukon Territory
    -Return to Top-
    Steve
    couple of questions if I could. What size end mill? What RPM.
    The other thing to note is lots of folks say that recutting your chips is a bad thing. I have a Fog Buster mist coolant system I use on my lathes and mills. It keeps every thing kool and the chips blown out of the cut.
    You have done a very good job of converting this mill. I think you will be making a lot of chips with it.
    Don't know if you have looked at Gwizard.com. They have a great program for figuring best feeds and speeds for lots of materials. I'm to the point I don't make a cut till I check to see what the program says I should use for feed and speed.
    Dave
Share This Page
