- Sep 10, 2013
- 594
Hi All.
I just finished making myself an RT2/OMW ball turning tool. I cut the frames out on my CNC Mill( DIY Grizzly G0704), so is within .001 or so, can't seem to figure out the tool bit grind to keep it from chattering so bad the finish is like I used a cold chisel to cut it out. The ball that is on the handle was the first one I made and have made several more trying to get a decent tool to work. So far I have to spend lot of time using a file on the ball in the lathe to get the chatter marks out. Then the ball is under size by a fair amount. I have tried several sizes from 1" to 2" and they all look the same. I know the tool in not the most ridged ball turner, but it is the easiest to us on my compound and cross slide QCTP type. Here are some pix of the frames and the bit grind. The frames are pinned together with 5/16" drill rod and bushed with 932 bronze and reamed +.001 over drill rod size. the frame seams to not have any slop, but can't figure this one out. I can get the bit to cut good in some spots, but not all the way around the ball, either it chatters on the left hemi sphere or the right just can't get it cut good both sides of center.
Thanks for looking.
CH
Thanks for looking.
CH
