[4]
Router Build
[10] Like what you see?
aeroHAWK
Active Member
Active Member
May 22, 2015
89
Likes
60
#61
SWEEEET! :encourage:
Very nice Jay! :cheerful: It's great to see you be successful. I can't wait to see it make chips.;)
jbolt
H-M Supporter-Premium Member
Dec 3, 2013
1,227
Likes
1,011
#62
Went and got a piece of MDF this morning and installed it on the table. Added some threaded inserts to the MDF for clamping light material or material that will not be heavily cut. I don't think these type of inserts will handle much more but I had a box of them so I will give then a try.
Went to do the first test run and wouldn't you know it, the UC100 wouldn't connect to Mach3. worked fine last night and now nothing. Uninstalled, reinstalled, rebooted, blah blah balh but no go. One of those moments I wanted to break things but kept my cool and went about searching for a solution. After several attempted fixes I dug out an old laptop and set it up with Mach3 and a copy of the Mach3 XML profile for the router. Low and behold it worked fine with the laptop.
During the install uf the UC100 plugin and USB drivers it prompted me that the firmware version was different and updated. After running a test program with the laptop I plugged the UC100 back into the PC and fired up Mach3. I got the same firmware message and let it update or change versions, not sure what it did but it now works again on the PC.
Here is the first test run. The VFD is slow to accelerate so the spindle was not up to speed when it started cutting. I need to figure that one out. I tried setting a 10 second pause at spindle startup on the spindle settings tab but it does not make a difference.
brav65
Sep 24, 2014
907
Likes
446
#63
Looks good for your first run. I can't wait to see some projects once you get everything dialed in. I wired up my power supplies today along with two circuit breakers. Getting close to being finished with the control box wiring. Thanks for sharing, it is motivating me to finish my router.
jbolt
Dec 3, 2013
1,227
Likes
1,011
#64
Here is a machine relief of a photo done in ArtCam Express. Roughing was done with a 1/4" ball nose end mill and the finish pass was done with a 1/8" ball nose end mill. I ran it slow to make sure everything moved in the right direction, which I pleased to say it did. At 25 ipm it took an hour to do both rough and finish passes.
My machine is maxing out at 100 ipm. I need to figure out if that is the max I can go or if I'm missing a setting somewhere. I expected to be able to move faster.
Jay
jbolt
Dec 3, 2013
1,227
Likes
1,011
#65
Here is some of my daughters line art converted to vectors in ArtCam Express. Lots to learn with this program. I wish I could justify their Insignia version but at $2500 for hobby use its just too much.
Routing was done with a 90 deg drill mill at 24K RPM/50 IPM. I need to get some different engraving tools to play with.
Jay
jbolt
Dec 3, 2013
1,227
Likes
1,011
#68
I got a dust collection system installed. The collector is a bucket lid shop vac that draws through a cyclonic separator which is supposed to let the particles drop out of the air stream before they get to the main vac tank (that's the theory anyway). I got the idea for the separator whist cruising the web. Fits perfectly under the machine.
The dust hood is a work in progress. This is the first iteration using material I had on hand. The sweep is made from some scrap 1/8" Burna rubber sheet I had left over from the mill way covers. The sweep attaches with rare earth magnets and a couple of small dowel pins to keep from being dragged off.
I don't like not being able to see he cutter so I picked up some 1/2 clear cast acrylic to make a longer hood to move the intake elbow a little further away from the spindle and hopefully offer a view of the cutting bit.
The white poly and particle board parts were designed in SolidWorks, exported as dxf files and imported into VCarve Desktop 8.0 to to the tool paths and then cut on the router. I have HSM Express in SolidWorks for CAM but it does not do tabs easily. VCarve does a nice job and is very easy to use. So far I am liking VCarve better than ArtCam Express.
dust hood 02.gif dust hood 03.gif dust hood 04.gif dust hood 05.gif dust hood 01.gif
jbolt
Dec 3, 2013
1,227
Likes
1,011
#69
I played around with the vcarve software and made a simple address sign out of some scrap rustic cherry flooring glued together. I need to work on the feeds and speeds. The texture had a lot of tear out. Could just be the softness of the cherry and/or the v-bit needs a better edge.
The tool path for the texture is just crazy at how much time it wastes making big moves across the part. Makes no sense to me. I got so frustrated watching it I had to walk away from the machine. I couldn't find a way to optimize the tool path in the program. I have a question posted about it in the software manufacturers forum.
Overall not bad for a first go. The vacuum system works great as is so I think I will leave it alone for now. Also the single cooling fan/radiator for the spindle works like a champ. The spindle never gets more than a few degrees over ambient temp.
jbolt
Dec 3, 2013
1,227
Likes
1,011
#71
Today's Project. 16" in diameter. The area clearance was done with a 1/8" carbide 2-flute end mill and then finished with a 60 deg v-bit. Total run time was 80 minutes. This is with the first coat of sealer. I will take more time on the finish of this one. No painting, just the clear finish on the rustic cherry.
aeroHAWK
Active Member
Active Member
May 22, 2015
89
Likes
60
#72
VERY NICE JAY! :encourage:
It's great to see your success with CNC. I'm glad it's working so well. ;)
roadie33
Dec 11, 2014
772
Likes
537
#73
Good work.
You need take a little more time tho when gluing your pieces together.
Try to match up the wood grain or at least keep the grains going the same way so it looks as close to a single board as possible.
The obvious glue lines distract from the actual piece.
jbolt
Dec 3, 2013
1,227
Likes
1,011
#74
Good work.
Mike, thanks for your comments.
This is a practice piece I did for trying different cutters, speeds and feeds.
The look is intentional. The glue lines are actually gaps. The material is scrap rustic cherry flooring. I have a bunch of it left over from a home I built or a couple many years ago. What you see came from the same board. I simply glued the tongue and groove together not concerned with how the joint would be. If I am not happy with the clear finish I may do some weathering and antiquing to make it look old.
Jay
jbolt
Dec 3, 2013
1,227
Likes
1,011
#75
I got the vacuum table built and setup. This is version 2 built to the extents of my work area. 1/4" closed cell backer rod or EDPM cord is used for the gasket. Grooves were cut with a 1/4" ball nose end mill to a depth of 0.2". The board was made from 2-layers of 3/4" HDF. The HDF is not as porous as MDF but still needed to be sealed. The 2-layers were laminated together with epoxy to insure no leakage between the air channels. Vacuum comes from a 5 CFM 2-stage pump plumbed to a 5 gal auxiliary tank.
20160410_120610.png 20160410_120618.png 20160410_120636.png 20160410_120715.png
[6]
[5] [7]
