    Dismiss Notice
Round wheel handle center hole shape
Discussion in 'QUESTIONS & ANSWERS (Get Help Fast Here!)' started by GoceKU, Jul 29, 2017.
  1. GoceKU
    GoceKU Macedonia Active Member Active Member
    221
    43
    City:
    Kumanovo
    State:
    Outside US / Canada
    -Return to Top-
    I've recently acquired this wheel handle, with a strange center hole, when i first seen it taught someone has made an mistake drilling it, because i've seen only round and square holes but wanted to ask, has anyone come across this style of mounting arrangement to keep it, or is it a mistake and i should drill it bigger to be able to use it in the future.
  2. RJSakowski
    RJSakowski H-M Supporter - Premium Content H-M Supporter-Premium
    2,530
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
    It would be the easiest way to key for a shaft. An end mill could do the job. The mating shaft would have two opposing flats and probably threaded hole in the end of the shaft to retain it.
  3. kd4gij
    kd4gij United States Active User Active Member
    1,129
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
    That was common the mating shaft is threaded then mill opposing flats and held on with a nylock nut jam nut
  4. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    2,220
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    That's more than likely a handwheel/handle off of a gate valve, globe valve or some other type of valve. Hard to say what time frame that is from.
    Bill W., Tozguy and kd4gij like this.
  5. kd4gij
    1,129
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
    You can either use as is or bore and key what ever works when you need it.
    4gsr likes this.
  6. dave_r_1
    dave_r_1 Canada Active Member Active Member
    376
    63
    City:
    Edmonton
    State:
    Alberta
    -Return to Top-
    It appears to make an excellent club the way it is. You can get a good firm grip on one side, and it's nice and solid and appears to have a decent mass. Best of all is that it doesn't look like a normal everyday weapon, so you can walk around with it in your hand, ready for action.
  7. Bill W.
    Bill W. United States H-M Supporter - Premium Content H-M Supporter-Premium
    69
    18
    City:
    Brookings
    State:
    Oregon
    -Return to Top-
    Agree with what 4gsr said. The shaft and handwheel of said gate valve would be made in that configuration to withstand the torque to open and close the valve.
    Otherwise, the hand wheel may spin if the shaft was round only. IMO...
    4gsr likes this.
  8. GoceKU
    221
    43
    City:
    Kumanovo
    State:
    Outside US / Canada
    -Return to Top-
    Must be extra large valve because this wheel is 195 mm diameter.
  9. kd4gij
    1,129
    113
    City:
    St. Petersburg
    State:
    Florida
    -Return to Top-
    That isn't that large. I have seen valve wheels 2ft in dia. 609mm
    4gsr and Bill W. like this.
Share This Page
