- Dec 20, 2012
- 9,422
Evening, Guys.
I have a new-to-me RF-31 that was used as a bowling ball finger hole drilling machine. It was never used to mill anything so it was in decent shape, and the guy only used a 1/2" R8 collet in there and never really took it out of the machine. On initial inspection, the upper spindle bearing was covered in grit and dirt so I changed the spindle bearings to FAG sealed angular contact bearings (I'll do a write up later). These are P5 class bearings, equivalent to ABEC 5, so should be pretty okay for this machine. I thought they would at least improve runout a little bit so I checked.
Runout inside the spindle nose with a Compact 214GA DTI (reads 0.0005") gave me a TIR of 0.002". To me, that's a lot! I got the same reading at 3 different spots inside the R8 taper. I then put a Tormach R8 collet in the spindle and slapped an Albrecht chuck in there. Runout at the base of the arbor was 0.0015" TIR and 0.006" at the end of a 3/8" OD dowel pin, 2" from the nose of the chuck. I got pretty much the same results with a Tormach ER-32 chuck holding the same dowel pin.
Now, I didn't expect a high quality result from a budget mill drill but I did expect much better spindle runout than this. So, my questions:
Mike
- What are you guys seeing for spindle runout on your machines?
- Where do you think the runout is coming from? I think it is the spindle, the drive sleeve or perhaps the accuracy of the quill bore where the bearings seat.
- I set preload by feel. I would guess somewhere around 20lb/ft of torque or a bit less. Since I used angular contact bearings the preload should not be critical. They run cool and vibration-free, with a temp of only 41 degrees C after 30 minutes at 1800 rpm. However, I am not absolutely certain that this amount of preload is adequate - what do you think?
- Are there other sources of excessive spindle runout I should consider?
Mike
