My ALSGS 500s power feed has a fouled tooth on the big Zytel plastic gear in the bottom of the unit. I removed the gear to replace it. The gear is retained with a wave washer and a snap ring.
I'm having difficulty replacing the snap ring because of the pressure from the wave spring washer.
Is there a trick to getting the assembly compressed to replace the snap ring and complete assembly?
Thanks
Thanks
