I purchased a replacement gib for the Y axis of my G0704. The only information provided by technical support from Grizzly was the factory utilizes the process of hand scraping to custom fit them to mills and then cuts them to the proper length. The replacement gib is approximately 12" long, tapered, smooth finish on both sides, and a notch on one end for the adjustment screw. I have found similar posts on forums, but no answers in-terms of how someone without the benefit of hand scraping expertise could accomplish the task. I assume you can't simply put the full length replacement gib in, adjust to a reasonable fit by moving the saddle back and forth, and then make marks on the gib in the front/back of saddle as a reference to cut to length. Also, what about the smooth finish in-terms of holding oil? No access to another mill. I would really appreciate some help.
