- Feb 7, 2013
- 2,485
My old band saw had a loose pulley wheel so decided to make repairs before getting into
some serious wood cutting. The 1.25 inch shaft on the pulley had a through hole only
and a sleeve inside the pulley for a slide on fit. A 5/16 bolt was in the hole and was
found to be broken in half. A key way would have been the best repair but removing
the shaft would have been a big job. Fortunately I had gotten an old set of reamers for tapered
pins on EBAY so decided to give it a try. After reaming out the hole, I used the lathe to
make a tapered pin to fit. Also I made a thick washer on a slight eccentric to apply pressure
to the pin so it would not work its way out. Also, the 5hp Briggs was burning some oil
so put in a new set of rings. Hopefully it is ready and willing for the season. View attachment 98888
The saw is a 24 inch Crescent band saw.
Note the muffler made from an old propane cylinder. It is quieter than the stock muffler available.
