Removing broken tap in non ferrus.
kellswaterri
Jun 14, 2013
27
Hi all,
this may not apply to watch or clock makers, if not please move it...has anyone ever used (ALUM) or potassium aluminum sulphate to remove a corroded screw or a broken tap in a blind hole...apparently this only works with non ferrus material...
All the best for now,
John.
It works best on carbide taps -and yes, I've used that trick and it works. Make a paste and put the part in a warm place just enough so the paste doesn't dry up too fast. Keep it damp for at least 4-6 hours -overnight if possible -the longer the better. The carbide will crumble when you pick at it.
I'm not sure if this works with HSS-type taps.
Ray
Hi all,
John.
