  • NOTICE: There are two new video channel areas set up, one for staff, and one for subscribing members. You need to create a folder. Then add your media to that folder. Once added, you can cut and paste the code at the bottom right to embed the media into a post on the forum.
    It works very similarly to YouTube, except videos are stored on our server. Click Here For The Video Channels
[4]
Removing a stuck chuck
[3]
[10] Like what you see?
abunai
Active Member
Active Member
Sep 16, 2017
66
Likes
27
#1
I'm trying to save a Logan 927 lathe.
Got a majority of it home.
I could not get the chuck off.
I tried the Belt and leg method. Use a belt to spin the gear to impact the chuck lathe on the bed.
Didn't work.
So I took the head and chuck off together.
Heavy.
I tried the impact gun, and it didn't work.
I have it soaking with PB Blaster now.
No idea how long it's been on. From what I've heard, the lathe hasn't been used in at least 10 years. Probably longer from the looks of it.
No rust on the outside.
Suggestions?????
I don't have the bed......yet.
Hope to get it home soon.
magu
H-M Supporter - Premium Member
H-M Supporter-Premium Member
Jun 6, 2014
135
Likes
81
#5
If it were me, I would try heat with the understanding that I might cook the bearings. I would put a torch on the chuck and slowly turn the spindle while running water through the bore. once it was good and hot I would try and break it free. If that didn't work, I'd just go with cutting the chuck off. This can be started with a torch or saw/grinder, or simply by taking the jaws off, firing up the lathe and doing what we all try really hard not to.... run the tool across the chuck.
Alternatively, there is a spindle on ebay at the moment for $99. Depending what your time is worth, that may be a more sensible option. I find that since I have a toddler running around a lot of things I would have pig-headedly done myself can't be justified anymore because it might take 6 months to get an honest days work done on something.
abunai
Active Member
Active Member
Sep 16, 2017
66
Likes
27
#6
I can see the threads through the face. It's normal right hand.
Don't see anything like a set screw or pin holding it.
Probably be easier to take off if it was still mounted.
Needed to just get it out. Don't know when the shack is being demolished.
I'll look for a good strap wrench.
picture attached.
Silverbullet
Active Member
Active Member
May 4, 2015
2,443
Likes
1,112
#7
I would use the pb blaster but I'd heat the threaded section up with a hand held propane torch. You don't need it red hot but enough you can't touch it about three hundred degrees. Then add the pb blaster off and on for several days as many times as you can. That and kroil the oil that creeps. It's good stuff. What the heat will do is expand the metal and eventually the pb will leach into the threads. Also Ck and make sure know one pinned the chuck to keep it on in reverse cutting. It'll let go really.
stupoty
Active Member
Dec 2, 2012
890
Likes
209
#8
Didn't work.
Heavy.
Suggestions?????
I had a beast of a time getting my chuck of my threaded spindle when I got my lathe . I luckily could unbolt the chuck from the back plate which i used a hacksaw blade on to cut through then used wedged to split the back plate for the last bit near the thread.
their was the tiniest patch of rust that had been holding the chuck extremely fast.
markba633csi
Active Member
Active Member
Apr 30, 2015
1,433
Likes
630
#9
I've never had anything rusted so bad I couldn't get it off with solvent soak and heat. Even a nut and bolt that was buried underground
for 27 years in my backyard I was able (just for fun) to unscrew after a good soak and some tapping.
Patience, patience
Mark S.
abunai
Active Member
Active Member
Sep 16, 2017
66
Likes
27
#10
I have it standing on end so the PB will, hopefully, soak into the threads.
Looking for a good strap wrench.
Also thinking of making something like tubocain made.
Shaft that goes through the spindle to hold it .
Trying to find a left hand thread anything here is going to be a problem.
NortonDommi
Active Member
Active Member
Nov 15, 2016
127
Likes
71
#12
I prefer a 50/50 mix of acetone and automatic transmission fluid (ATF) as a penetrating oil.
Add a little every day for a week or so, and then try again.
(....and if you try any heat, be careful as the acetone burns!)
-brino
50/50 Kerosene and ATF works better as with Acetone the Acetone evaporates too fast. Sometimes I add 20% Isopropyl Alcohol to the above mix for fast penetration but it has to be kept in an airtight container.
markba633csi
Active Member
Active Member
Apr 30, 2015
1,433
Likes
630
#13
Liquid wrench has always worked for me- but I have no affiliation with them
I also found it makes a good fluid for drilling and tapping aluminum
Mark
abunai
Active Member
Active Member
Sep 16, 2017
66
Likes
27
#14
Looking at it again today, I have to mount it better.
The head is off the bed, so it just moves around to much.
It's going to come off, one way or another.
abunai
Active Member
Active Member
Sep 16, 2017
66
Likes
27
#15
Worked on it again today.
Tried the action wench, but just can't hold it firm enough. Head not attached to bed.
Decided to remove the chuck. I did mark it to put it back in the same place.
It made it so much easier to work with.
I made an angle flat head to remove the screws holding the front bearing in.
Hoping there was enough room for it to work.
It did and I got the whole shaft out.
Now I can hold the shaft in the press, put back the chuck, and hopefully remove the whole thing.
Bearing feels OK, but it doesn't look that great. I may replace it.
Chuck K
Mar 1, 2013
819
Likes
294
#17
If that is the original New Departure bearing, it would behoove you to try to save it. I have heard of people hanging a lot of weight on a bar held in the chuck and lubricating it. Come back the next day and the weight is on the ground. Never tried it but it sounds like it would work.
abunai
Active Member
Active Member
Sep 16, 2017
66
Likes
27
#18
It is a New Departure bearing.
It feels good, but looks really dirty. Lots of brown staining around it.
Once I get the plate off I can see the bearing better.
Going to cut two "V" blocks to hold the shaft in the press.
Reinstall the chuck.
I'll try the "hanging a weight" trick and see how it works.
It will come off. I will not be defeated by it.
eeler1
Dang, buggered that up too!!
Mar 7, 2014
361
Likes
160
#19
The 927 should have a 2 & 1/4-8 threaded spindle, I've heard of, but never seen, any modified with a locking screw. I'm thinking it's just stuck, not unusual if it's been on there for 10 years. As mentioned above, you may be able to remove the front portion and turn down the back plate. Replacing the back plate is no big deal, just another cost. Get used to it.
magu
Jun 6, 2014
135
Likes
81
#20
If you already have the chuck off, I would just split the back plate and be done with it. Backplates are reasonably cheap, if you mess around with it long enough you may break or damage something more expensive.
chips&more
Active Member
Mar 19, 2014
2,068
Likes
1,394
#21
Make a large bolt with left hand threads that will go through the head stock spindle hole and be secured at both ends of the faces at the spindle hole. With that bolt you can hold fast the spindle and unscrew the chuck. With this method you will not be using gears, slipping strap wrenches etc. that could break something or at least get you high blood pressure. This method will just hold the spindle. The only down side is you will need to make the left hand threaded bolt. And sorry, a right hand thread will not work…Dave
Mikelkie
Iron
Registered Member
Nov 19, 2017
5
Likes
20
#22
Some years ago a friend of mine (he's in the UK now) had the same problem. He welded a mandrel to a piece of 2"pipe to form a t at midpoint of the pipe, in the pipe he put a piece of 35 mm round bar and welded the ends closed. I was then ran the lathe at slow speed with the t pipe going 'klonk klonk' and after about 40 minutes the offending chuck was loose. I'm don't know if it was any good for the head stock bearings though .
Nogoingback
Active Member
Active Member
Oct 18, 2016
478
Likes
258
#23
When I changed the bearings on my lathe, I clamped the spindle into a vice with a thick piece of leather wrapped around it. Only tightened
it enough to hold it. If you do that and bolt a "handle" to the adapter, you could heat the adapter up and then smack the handle with a hammer. That might shock it loose. If it slips, it won't damage the spindle OD.
ch2co
Grumpy Old Man
Jan 9, 2013
781
Likes
507
#24
Impact wrench turning the biggest bolt you can find which is mounted in the chuck??
CHuck
Bob Korves
Jul 2, 2014
4,188
Likes
4,375
#26
Make sure to work the stuck threads in both directions, to get it a slight bit loose. After it moves a tiny bit, the outcome is certain. Sometimes, going in just one direction only tightens whatever is blocking the threads even tighter.
Silverbullet
Active Member
Active Member
May 4, 2015
2,443
Likes
1,112
#28
It may take several days to get the penetrating oil to work. As I said before heat it up the chuck mount not the bearing. Do it as many times a day as you can it takes time . Brute force will brake things . Go easy it will work if you take the chuck off the mount it will be better and the oil can be added in front too.
ch2co
Grumpy Old Man
Jan 9, 2013
781
Likes
507
#29
I tried the impact gun. Didn't work.
That's the first way I use to remove chucks.
Works most of the time.
Did you try to reverse the direction of the impact wrench. I have found that the shock of first forward then backward impacts done in succession
i.e. many cycles of switching forward then backward can remove nuts (chucks?) that applying just the single direction won't budge.
abunai
Active Member
Active Member
Sep 16, 2017
66
Likes
27
#30
Never saw that candle wax trick.
I wonder if it might work.
Haven't had time to do anything to it.
Hopefully tomorrow.
[6]
[5] [7]
