A customer of mine has a yard with a steel fence around it, with a double-gate, one side has a regular latch that opens fine, and the other side (to make the opening twice as wide) is currently fixed in place by a steel rod that goes into a hole in concrete, which was clearly made for you to be able to lift it up and out of the hole and then swing the gate open.
However, right now, from years and years of not being used, it doesn't move by hand (the rod neither rotates or can be lifted up. I want/need to get the rod free in a non-destructive manner, the rod itself is about 1/2" in diameter, with about a 3" handle (the rod just bent at a 90 degree angle for this).
I'm currently considering hammering not particularly hard with maybe a dead-blow hammer or a soft-faced hammer on the handle to get the rod to rotate, and/or use a jack under the handle to lift the rod up.
Any other suggestions?
