- Oct 13, 2012
- 175
I recently purchased a 3.8HP treadmill motor on ebay. Unfortunately, the packing could have been better and the motor appears to have been dropped on it's spindle and the back of the motor housing broken out. The seller was pretty cool and immediately gave me a full refund including shipping. He told me not to bother shipping back.
I don't think the shaft, stator, or bearings were damaged. I discovered the damaged housing when I applied 12V DC to the motor to test if it would spin, which it did. I have this crazy idea of trying to recover the motor. I'm looking for a sanity check on my approach or alternate ideas.
Looking at the pictures, it looks like I could machine out the rough area that was created when the housing broke and replace it with a piece of aluminum machined to host the top of the bearing and press it back into the housing. The two screws holding the housing on could be used to secure the new aluminum bearing cover. Since I want to convert this motor to a servo, I could also make provisions for mounting the encoder.
Any thoughts, ideas, or caveats?
Oh, yes - that's the destroyed fan you see in the first pic that use to be on the end of the motor. I was planning on removing it and mounting a separate fan for independent cooling anyway.
-Freeman
-Freeman
