I have a small stainless polishing project. (Need to take from my mill finish, to 60 grit, through to 5000 grit 3M Trizact with my 3-inch orbital sander, and then Black/Brown/White/Green/Blue stick polishes. Each has a dedicated to 6-inch polishing wheel. My little 6” 2.1 amp Ryobi sort of works—worked on a 6 square inch surface (of like 40 such pieces that need to be done) and got the finish I want. But it was unacceptably slow—bogs down under the pressures needed to work at a reasonable speed. It will be worth a couple of hundred dollars for me for this project to invest in the next-grade up. I don’t do enough of this work for a Baldor-class machine. But 3/4 hp or 1 hp unit would be great.
I see a few such units in my Googling.
https://www.ebay.com/itm/8-LONG-SHA...LISHER-GRINDER-CLEANER-BENCH-TOP/350789972932. (Same as the Amazon product but cheaper)
Or for $300
Any recommendations?
Thanks.
-Bill
8" LONG SHAFTS 1HP H D TOP BENCH BUFFER POLISHER GRINDER CLEANER BENCH-TOP - - Amazon.com
www.amazon.com
Or for $300
Shop Fox w1847 Buffing System - - Amazon.com
www.amazon.com
Thanks.
-Bill
