  2. We want to wish everyone a healthy, happy New Year, full of joy and success. God bless you, and thank you for supporting The Hobby-Machinist.
    Dismiss Notice
Rate the Harbor Freight Tools Thread- Pass or Fail?
Discussion in 'TOOL JUNKIES - TOOLS & TOOLING (Love Tools? This Is Your Forum)' started by Nels, Dec 2, 2011.
  1. rsting
    rsting United States Iron Registered Member
    0
    1
    City:
    granby
    State:
    Missouri
    Has anyone tried the quick change tool post set for mini lathes? I'mthinking of trying one, but ddon'twant to waste my money if tthey're just awful.
  2. kvt
    kvt Active User Active Member
    436
    83
    City:
    San Antonio
    State:
    Texas
    well 4 1/2 inch angle grinder FAIL Twice, NOt sure what happened this time but it started smoking and slowing down, shut it off and put it on the floor. Guess I need to find me a good 4 1/2 inch angle grinder that will hold up. First one was bearings seized up and died. If anyone knows of a decent one at a decent price let me know.
  3. pebbleworm
    pebbleworm Active User Active Member
    34
    28
    City:
    San Francisco
    State:
    California
    Last time I needed an angle grinder, I checked Amazon and they had a Bosch for less than $30.00US. It has worked well, and arrived 2 days later. Always worthwhile to check Amazon since their algorithm occasionally prices things very, very low.
  4. kvt
    436
    83
    City:
    San Antonio
    State:
    Texas
    Thanks, I got about 3/4 of the way through cutting up a axel so I could heat the pieces in my little forge, when it smoked. Put a kink in my plans.
  5. Billh50
    Billh50 Active User H-M Supporter-Premium
    704
    113
    City:
    New Britain
    State:
    Connecticut
    I have had good luck with the 4 1/2 " angle grinder with the paddle switch. I have 2 that lasted me about 5yrs with a lot of use. I also have had the ones with the slide switch ut they don't seem to last as long for some reason.
  6. kvt
    436
    83
    City:
    San Antonio
    State:
    Texas
    This was one with the switch on the side, THe prior one was one that had the switch on the back, It at least lasted a few years, but not that many, The new one lasted just past the warranty only because I did not use it much for a long time.
  7. Charles Spencer
    Charles Spencer Active User H-M Supporter-Premium
    585
    93
    City:
    Worcester
    State:
    Massachusetts
    A follow up:
    I had also sent a complaint via the web. This was the response:
    "Dear Charles,
    Thank you for your recent inquiry.
    We do apologize, but the part that you need is not available as a replacement part from Harbor Freight Tools. Would you like us to issue a prepaid shipping label to have the item returned and replaced?
    We look forward to hearing from you.
    So apparently it's better to call than to use their web site.
    I did decline their offer.
    I also received an email today telling me my new one had shipped.
  8. mcostello
    mcostello Active User Active Member
    72
    28
    City:
    lancaster
    State:
    Ohio
    Was in the store and looked at tapered sanding rolls, They disassembled themselves in the package. Their timing was off as They did not wait until they were being used, fuse must have been too short.:D
    JimDawson likes this.
  9. roadie33
    roadie33 Active User H-M Supporter-Premium
    381
    63
    Ozawkie, Ks
    City:
    Ozawkie
    State:
    Kansas
    I just bought one of these Threaded Insert Riveter Kits, http://www.harborfreight.com/45-piece-threaded-insert-riveter-kit-1210.html and am using it to do some mods on the HF Sand Blast Cabinet I bought earlier this summer. Just got around to putting it together.
    The problem is I bought some of the Metric insert Nuts on Amazon and the tool only has the SAE Mandrels. I've found some metric Mandrelss on Amazon and Ebay that look to be the right size, but am not sure if they would fit this gun. I want to know if anyone else has one of these and if they found the correct Metric Mandrels that fit.
  10. juiceclone
    juiceclone United States Active Member Active Member
    91
    28
    City:
    Boca Raton
    State:
    Florida
    Have to add this re: HF 4 ½” angle grinder. I never can leave something alone when it fails. Been thru 3 HF angle grinders in prob 15 years now…haven’t picked up a hacksaw since I discovered them.. Couple of days ago, my current one started to shake/wobble the cutoff disk so bad, I went out and bought another HF $14.99 one. Now I have two bad ones so, ….. took them apart to make one good from the bits. When I got to the main bearing that supports the shaft at the wheel (output) end I pulled the clip holding it (the “bearing” ) in and pulled in out of it’s bore. What I found was it was not a bearing at all. Literally made to appear like one, but it’is just a disk of steel the size and shape that you would expect a ball or roller bearing to be. The steel shaft rode in this steel …thing… and of course wore out till the shaft clearance got too great to ignore. Being steel, I wouldn’t even call it a bushing..The only lube available to it would be the thick Chinese grease that came in the housing,. Now this is the most heavily loaded rotating piece in this thing. I have to wonder if this is one plant somewhere in China just making crap and getting away with it, or if this is actually to specs from Harbor Fright. Or can something like this actually be an accepted “bushing” ???
  11. JimDawson
    JimDawson Global Moderator Staff Member Director
    3,186
    113
    City:
    Sandy
    State:
    Oregon
    That's amazing! I'm glad you posted pictures because I wouldn't believed it otherwise.:confused:
  12. silence dogood
    silence dogood United States Active User H-M Supporter-Premium
    118
    43
    City:
    pendleton
    State:
    Oregon
    I was tempted to buy this tool until I found out that HF does not sell extra threaded inserts. That makes about as much sense as buying an ink jet printer, but the same store does not carry the ink cartages. I don't mind ordering them, but it would be nice to get the inserts locally.
  13. roadie33
    381
    63
    Ozawkie, Ks
    City:
    Ozawkie
    State:
    Kansas
    I checked locally and the prices were outrageous.
    I ended up ordering the sizes I needed by the 100 on Amazon, and they were cheaper than buying 20 locally.
    The problem I have is finding the right size mandrels in Metric to fit this gun.
  14. BGHansen
    BGHansen United States H-M Supporter - Premium Content H-M Supporter-Premium
    681
    93
    City:
    Charlotte
    State:
    Michigan
    Couldn't resist the 25% discount coupon for Labor Day weekend, bought a 7 x 12 metal cutting band saw. Hard to beat a normally $900 saw for $675. I've only made a few cuts, would rate it a big plus. Packaging, fit/finish are very good. Manual is not up to Grizzly standards, but is very acceptable. I've read that the supplied 6 tpi likely carbon steel blade is garbage so I've got $100 worth of bi-metal blades on order. Using TrimSol for coolant which is great also. My first cut was through a 2" CRS round which took about 45 seconds. Cut was almost perfectly square. Really like the quick acting vise too.
    Bruce
    4gsr and Fitter Bill like this.
  15. roadie33
    381
    63
    Ozawkie, Ks
    City:
    Ozawkie
    State:
    Kansas
  16. bfd
    bfd United States H-M Supporter - Premium Content H-M Supporter-Premium
    58
    28
    City:
    nipomo
    State:
    California
    I too have a HF close buy. I have some of their tools. 1 ton gantry crane, muffler pipe expander 6" digital calipers, If I was making a living with them I wouldn't have. at best all Chinese tools are a kit and need reworking
  17. bfd
    58
    28
    City:
    nipomo
    State:
    California
    42" red tool boxes (3) pass 1.5 tom alum floor jack pass jack stands pass. hand grinder fail not due to ability but lack of a deadman switch, Use with a wire wheel and have it jump off the part and into your shirt you can't just let go, you need to find the moving switch. bad, it hurt
  18. Nogoingback
    Nogoingback United States Active Member Active Member
    24
    8
    City:
    Vancouver
    State:
    Washington
    I bought one of the 44 inch 13 drawer roll cabinets several years ago: Major Pass. I have a couple of the old Craftsman roll cabs (as in 40 years old) and I think it's just as good.
    I think I payed about $350.00, which is a lot of tool box for the money.
    I also bought a couple of packs of metric and inch Allen wrenches off the sale table one time. They were 5 bucks, so I figured I couldn't lose. They are also a Pass: they've been
    fine and they get used regularly.
    'Course, tool boxes and Allen wrenches don't fail often, so I guess my chances were good.
  19. george wilson
    george wilson United States Global Moderator Staff Member H-M Supporter-Premium
    626
    113
    City:
    Williamsburg
    State:
    Virginia
    I am surprised that HF Allen wrenches would be good. I have found that cheap Allen wrenches are too soft,and VERY soon fail,with their corners getting dubbed off till the wrench just rotates in the hole. I ONLY buy good brands,otherwise they are soon useless.
  20. roadie33
    381
    63
    Ozawkie, Ks
    City:
    Ozawkie
    State:
    Kansas
    I found the L shaped ones are good, but the T handle ones are prone to rounding off.
    Took care of that issue by cutting the longer end off the L shaped allen keys, use 12" pieces of round stock of various sizes, drilling one end close to the Allen key size and silver soldering the cutoff into it then soldering a cross piece to the other end.
    Now I have SAE and Metric size, very strong T handle Allen wrenches that will reach into about anywhere.
  21. george wilson
    626
    113
    City:
    Williamsburg
    State:
    Virginia
    The "L" shaped ones are the ones I meant. I have a set of the long T handle ones,but they are of a good brand,which my old head can't remember right now! Elkind?
  22. Fabrickator
    Fabrickator United States Active User Active Member
    274
    63
    City:
    Lakewood
    State:
    California
    Some extra hand tools to keep in my trailer, 3- 4 1/2" angle grinders (one each for cut-off disk, wire wheel and sanding), power hacksaw for no particular reason except it comes in handy occasionally, horizontal 14" band saw, shorty angle drill, heat gun, and some other stuff I just use occasionally. Certainly not pro quality to be used daily in your occupation, but good enough for, wait for it: occasional use and the price is right.
  23. Nogoingback
    24
    8
    City:
    Vancouver
    State:
    Washington
    Honestly, I was surprised as well. I had very low expectations when I bought them. The packs I bought are labeled "Pittsburgh", which is, I guess, one of the HF brands. It's interesting to
    scan down through this thread: some people have good experiences and some are terrible. In my view, that's the biggest problem with HF or other retailers the deal in a lot of import stuff:
    we usually have an expectation of a certain minimum level of quality from a given retailer. With HF, you never know what you're going to get, so it's hard to generalize about them. Also,
    I think that with the Chinese stuff, there is little consistency from factory to factory, and so different suppliers will deliver goods of different quality.
    I had a conversation with an employee at Grizzly in Bellingham one time that was instructive. I was considering buying their 11" bench lathe and I asked him a question about parts availability
    over the long term. He assured me that Grizzly tries to support their customers with parts, but then told me a story that suggested what the real situation is: Apparently Grizzly has a
    representative in China who's responsible for working with suppliers over there. At some point, Grizzly stopped receiving product from one of the factories they did business with. The
    rep tried repeatedly to contact them and got no response, so eventually he travelled to the factory itself to find out what the situation was. When he got there, the factory was empty and
    abandoned.
    Not trying to pick on Grizzly in particular here, but that's what we're dealing with. (I bought a old Logan in the end).
  24. jpfabricator
    jpfabricator United States Active User H-M Supporter-Premium
    581
    113
    City:
    Henderson
    State:
    Texas
    The link twist drive belts pass.
    Sent from somwhere in east Texas by Jake!
  25. owl
    owl United States Active Member Active Member
    12
    8
    City:
    Missoula
    State:
    Montana
    regarding the 4 1/2" angle grinders, mine started acting up, so I took it apart. The problem seemed to be that the brush holders are almost tinfoil thin, and the brush springs are not very good. I stretched out the spring as best I could, and bent the parts for the brush holder back in shape so that they locked together, re-installed 2 phillips head screws, and it works fine again. I suspect that if I had let it go, that whole assembly could have burned up, but I got to it in time.
  26. Superburban
    Superburban United States Active Member Active Member
    75
    28
    City:
    Grand Junction
    State:
    Colorado
    The same could be said about many American companies. How long is a good time period for a company having repair parts available? Try finding many of the emissions parts for any car from the 70's. Or any lathe made in the 70's. Yes, many companies will get you parts at an outrageous price, and a six month lead time.
    I would think a company like Grizzley would at a minimum have the company provide them with drawings and specs of every part, so Grizzley could have parts made down the line, or give or sell the costumer the drawings, so he could make them, or get them made. Grizzley does have a great system for parts, but I do have a problem with them (And most other companies) not listing older parts, when changes have been made to a product.
    I would love to see companies place their parts specs in the public domain, when they go bankrupt, but I know that is only a dream.
  27. george wilson
    626
    113
    City:
    Williamsburg
    State:
    Virginia
    I recall that Sears used to guarantee spare parts availability for 10 years. I think that was a reasonable length of time. Years ago I had a LeBlonde Regal 10" x 24" lathe,made for the US Navy in wwII. Leblond Still had SOME spare parts for it even in the 70's. But,the trick was,they wanted ME to pay for STORAGE since WWII ! I thought that was outrageous of them. Let their parts rot on their shelves for all I care!! I sold that lathe.
  28. BGHansen
    681
    93
    City:
    Charlotte
    State:
    Michigan
    Was given a 90A MIG welder; would have to rate it a fail when compared to my Hobart Handler 190. Lots and lots of spatter because it's an AC machine instead of DC. My project today is to convert it to a DC welder with a full-wave rectifier and electrolytic capacitor. Maybe then it'll be OK. If I'd have purchased it new my total investment would be about $150 to make it run DC. Was just at Menards and saw a Campbell Hausfield with comparable ratings for a little over $200, assuming that one is a DC already.
    Harbor Freight $80 retail ($60 on sale) welding table, big pass for me. Sure, there are better ones out there for $1000, but it works great for my purposes.
    Bruce
  29. alloy
    alloy Always looking for the next tool score H-M Supporter-Premium
    296
    63
    Vancouver, WA
    City:
    Vancouver
    State:
    Washington
    I've been using these Harbor Frieght extendable ratchets for some time now. I like not having to not have to take a short ratchet, and a long one in my small tool box when I go to the wrecking yard. I use the 3/8" to break transmission mounting bolts lose because I can't get use a 1/2" socket on one of them. I lean on it pretty hard and it just keeps coming back for more.
    I give them a 10 out of 10.
    http://www.harborfreight.com/14-in-x-38-in-dual-drive-extendable-ratchet-62312.html
    http://www.harborfreight.com/12-in-drive-extendable-ratchet-62311.html small ratchet.jpg
Share This Page
