- Feb 2, 2013
- 3,622
Fail - 115 piece Titanium Drill bit set. Drills not consistently hardened. Had one catch and untwist.
Fail - AR-8-RH carbide tipped lathe cutting bits. Junk.
Fail - Tire changer. Only thing good was the bar which well works as good as a bar.
Fail - Every air tool. Buy an Ingersol Rand impact wrench and compare to HF's. No contest. Most of the air tools don't work right out of the box.
Fail - Box end wrenches. Had one split while tightening a header bolt. That was a bloody mess.
Pass - O-ring assortment, cotter pin assortment.
Pass - welding cart
Pass - 4 1/2" angle grinder
Pass - bearing race install tool, slide hammer.
Most of the HF stuff is of poor quality. I use them mostly for mostly sacrificial tools.
HF 90 amp Flux Core Mig Welder using Lincoln Innershield 211, .030" wire is a
Pass:winner:.
View attachment 47701View attachment 47700
Although it is by no means made to be used where life and limb is at stake.
But if you're trusting your life to a $100 welder, there's not much help i can offer you
anyway.
thanks for reading!
mike)
Here's my HF stuff:
4x6 Saw----pass (after a little help:whistle
20 Ton press----pass
4 1/2" angle grinders------pass I have one that is very old and it just won't quit. Switch burnt out very shortly after I bought it...no parts available...just put a toggle switch in it and it's still going.
electric chain saw sharpener---pass
2 Ton shop crane---pass
Rolling cart that has been severely abused---pass
Mig welder cart---pass (after some help)
Auto darkening helmet-----?? Replaced it with another brand, but still use it some.
There's more, just can't remember them right now.
