- Apr 16, 2019
- 745
I need to scribe new marks on the cross slide dial on my bench lathe since I replaced the cross screw with a 5/8-10 . Plan on setting up the dividing head on the mill but the quill will need to be locked since I plan on using sharp HSS tool , like a threading tool turned sideways. Had 2 small pieces of 1” aluminum that wasn’t quite the same length but close enough to work , ( you can see one side was cut out of square ) trued the sides , drilled , taped counter bored then sandwished a .032 piece of cardboard with the Allen cap screws . Just used a center punch mark along with the tailstock to locate . Drilled and bored to size . Seems to lock well.
