F
f350ca
Forum Guest
Register Today
Unless it has brushes, you can't change the speed by dropping the voltage. Induction motors use the line frequency to set they're speed Dropping the voltage may slow them a bit as there isn't enough magnetism generated to overcome the load and you get slip. They generate a LOT of heat then and very little torque.
Greg
Greg
