    Dismiss Notice
PWM Motor Speed Control
Discussion in 'ELECTRICAL ISSUES - POWER YOUR MACHINES & SHOP' started by old toolmaker, May 22, 2017.
  1. old toolmaker
    old toolmaker United States Active Member Active Member
    42
    18
    City:
    Buffalo
    State:
    Minnesota
    -Return to Top-
    I have an old drill press having a 1/4 hp AC 115 volt split phase motor from the 1950's.
    Can I use a PWM motor controller to control the motor speed? There are several available on EBay.
    I am looking for a quick way to adjust speed other than changing belts. Most all my work is with smaller drill bits.
    Dick
  2. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    3,807
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    I am by no means an electronic genius, but I think PWM only works for DC motors.
  3. old toolmaker
    42
    18
    City:
    Buffalo
    State:
    Minnesota
    -Return to Top-
    Hi Bob,
    Thanks for your response.
    Maybe the acronym I used (PWM) is not correct and I just assumed it was. There are cheap devices on E Bay that are meant for use on AC motors which I have on my drill press.
    These devises are advertised for use on AC motors but I realize there are several kinds of AC motors. Mine is a split phase motor. I am not an electrician or electronics expert by any definition, so I need some guidance.
    Dick
  4. rgray
    rgray Active User H-M Supporter-Premium
    325
    83
    City:
    Helena
    State:
    Montana
    -Return to Top-
    I believe you need a brushed a/c motor to use one of those cheap speed controls on. motor label will say a it's an a/c d/c motor.
  5. old toolmaker
    42
    18
    City:
    Buffalo
    State:
    Minnesota
    -Return to Top-
    I forgot to mention in my last post that unit I am looking at on E Bay is very similar to what Grainger sells for router speed control. You plug it into an AC 115 V outlet and plug the motor cord into the unit and it has a speed control knob.
    Dick
  6. old toolmaker
    42
    18
    City:
    Buffalo
    State:
    Minnesota
    -Return to Top-
    This may sound like like a silly question, but how can a motor be both AC and DC?
    Dick
  7. markba633csi
    markba633csi United States Active Member Active Member
    402
    83
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Sorry Dick it won't work with a split phase motor, don't waste your money. It has to be a brush type motor, or a shaded pole induction type (fan motor).
    Mark S.
  8. markba633csi
    402
    83
    City:
    Mountain View
    State:
    California
    -Return to Top-
    There are ac/dc types and they have brushes. They don't have great speed regulation. I believe vacuum cleaners are one example. Some types of power tools.
    Mark S.
    ps I think Wikipedia has some info on them, if you're interested.
  9. old toolmaker
    42
    18
    City:
    Buffalo
    State:
    Minnesota
    -Return to Top-
    Thank you, Mark.
    I went and looked at my motor information plate and it does not say split phase. I don't know where I got the notion that it was. How would one know if it is split phase?
    If it is not split phase would the motor control work?
    Dick
  10. chips&more
    chips&more United States Active User Active Member
    1,254
    113
    City:
    Danville
    State:
    California
    -Return to Top-
    Show us a pic of the motor.
  11. f350ca
    f350ca Canada Active User Active Member
    1,647
    113
    City:
    Calabogie
    State:
    Ontario
    -Return to Top-
    Unless it has brushes, you can't change the speed by dropping the voltage. Induction motors use the line frequency to set they're speed Dropping the voltage may slow them a bit as there isn't enough magnetism generated to overcome the load and you get slip. They generate a LOT of heat then and very little torque.
    Greg
  12. old toolmaker
    42
    18
    City:
    Buffalo
    State:
    Minnesota
    -Return to Top-
    Greg,
    Would I see exterior brush caps if my motor has brushes or are some internal?
  13. f350ca
    1,647
    113
    City:
    Calabogie
    State:
    Ontario
    -Return to Top-
    Your split phase phase motor won't have brushes Dick. Things like treadmills use them to easily get variable speed as do hand drills. Most power hand tools use DC motors as they develop high torque in a small package.
    One more caution Dick. Some really old AC induction motors had brushes. They were called repulsive / induction motors. They won't work with a variable voltage either.
    Unless the plate says DC or AC/DC it won't slow down. Or not for long anyway.
    Greg
  14. old toolmaker
    42
    18
    City:
    Buffalo
    State:
    Minnesota
    -Return to Top-
    Thanks, Greg
    I will probably use the drill press as it is. It is an old Toro that I rebuilt and it is wired for forward and reverse, but it is inconvenient to change belt positions on the step pulleys. If it was a Walker Turner or old Delta it might be worth the effort.
    Dick
    f350ca likes this.
  15. f350ca
    1,647
    113
    City:
    Calabogie
    State:
    Ontario
    -Return to Top-
    Not cheap to do but you could replace the motor with a 3 phase one and use a VFD variable frequency drive to change speeds.
    Or there have been many posts with people using a treadmill motor and the PWM controller to get variable speed.
    Greg
    Bob Korves likes this.
  16. silence dogood
    silence dogood United States Active User H-M Supporter-Premium
    173
    43
    City:
    pendleton
    State:
    Oregon
    -Return to Top-
    That is not a silly question, but an excellent question. AC/DC or also known a universal motors are usually small motors that you find on portable tools and small appliances such as vacuum cleaners. Universal motors are basically a series wound DC motor with some modifications. The main mod is a added compensating winding so it will run on AC better. Usually a thyrister controller is used. You know those lamp dimmers for regular light bulbs. Same type of control. Since the motor is only 1/4 hp. you may be able to use an old appliance motor with a dimmer switch. Just make sure the dimmer can handle the current.
    brino and f350ca like this.
  17. silence dogood
    173
    43
    City:
    pendleton
    State:
    Oregon
    -Return to Top-
    PS an old sewing machine motor might work.
  18. hman
    hman Active User H-M Supporter-Premium
    990
    113
    Tempe. AZ -and- Corvallis, OR
    City:
    Tempe
    State:
    Arizona
    -Return to Top-
    I'll offer a cautionary note here. Picked up a relatively new looking Singer sewing machine at Goodwill a couple years ago, just to check out the motor and speed controller. The motor's nameplate says 120V 60W (or about 1/12 HP). That's way too small for a drill press (which is what the OP was asking about). Might be OK for a micro drill press, though.
    <Edit added> - My used sewing machine motor, previously offered, has been given away.
  19. silence dogood
    173
    43
    City:
    pendleton
    State:
    Oregon
    -Return to Top-
    Red face department. You are right. Should have check it out.
  20. rolleikin
    rolleikin United States Iron Registered Member
    5
    3
    City:
    Burke
    State:
    Virginia
    -Return to Top-
    No. You cannot. AC motors are trickier to control. Some AC motors (like fans) can have some kind of crude speed control. 3 phase AC motors can be controlled very accurately. Same goes for DC motors. Your drill press is not one of them. Use your belts to change speeds.
    Sent from my SAMSUNG-SM-T217A using Tapatalk
  21. ammomfg
    ammomfg United States Iron Registered Member
    0
    1
    City:
    Los Angeles
    State:
    California
    -Return to Top-
    Unless you don't care about possibly burning up the motor, I don't recommend using PWM, VFD, etc on any older motor, they most often do work, however because of the way these systems work a newer motor design that's better able to deal with the inductive heat is a better deal.
    PWM - Pulse Width Modulation is a fancy way of averaging a lower voltage to control a DC motor while still getting the higher torque of using the higher voltage, it's just on average the voltage is lower. This is the simple answer, there's more to it than this, but most simple implmentations will have a pulse rate (usually a few khz) and a duty cycle of whatever the voltage is. So 12V w/60% duty cycle is an average voltage of 8V. The sometimes encountered problem if you're running it quite a bit, is the PWM freq is constantly turning the motor on and off, which can lead to inductive heating in the coils armature, etc.
    VFD - Variable Frequency Drive is much more complicated and is kinda the go-to for most AC motors, the VFD system can change the pulse frequency (so from 60hz AC line to 30hz) it can change the voltage, etc. Unlike a PWM system that operates in open loop control, most VFDs are closed loop. meaning they can "read" motor state, either by measuring back EMF through the feedlines, and a lot of other complex means. I've never seen a VFD burn up a motor, however I won't say it can't happen.
Share This Page
