Brand New 935 arrived a while ago. I uncrated it, but left in on the pallet for stability. Now it's time to lift and move it, but I can't get it to balance.
I'm using a 2-ton Engine Hoist and the lifting eye. The motor is basically vertical, the table is at the column, and the knee is almost all the way down. I've unscrewed it from the pallet, and I've moved the ram forward to the point that the lifting eye is directly above the face of the column. When I lift the rear lifts first, and I can't lift the front by hand. I'm not that strong, what I'm suggesting is that it's not even close.
Questions:
1) How far forward can I move the ram when I'm lifting the machine? Have I gone too far already?
2) The (online) manual shows using the lifting eye, but the motor is missing (a detail I missed in previous viewings). Do I need to take the motor off to use the lifting eye successfully?
3) Is there anything else I'm missing?
Thanks for your help.
L
Questions:
L
