- Jan 29, 2013
- 114
Wow, Terry,
That was a great bit of work you did for me! Thanks so much. I have to confess, I have a "Machinery Handbook"--can't remember which version but I got it new. I just couldn't make heads or tails out of it because I was in a hurry and also because I didn't understand the terms. With what Terry just said, it makes a lot more sense now. I very lazily asked this question of all of you because was tired of trying to figure it out. Now I feel bad because Terry just did all my work for me. However, you did also give a lot of other information that is probably splattered around the book and you very nicely summed it all up.
The dowel pin that I have is a 6 mm 18-8 SS. +.004 to +.012. I'm pressing it through unknown chinese steel thru a 6 mm hole hardened bearing and into the other side of the chinese steel. The roller bearing would be the most difficult hole size to alter, so the dowel pin may need to be sanded in a 5C collet on the lathe to the proper tolerance as Terry said and I'll sneak up on it with the cloth until it mics right as noted. It can be a pretty permanent installation, but I wouldn't mind being able to take it apart to replace the bearing if I ever had to. There are actually 5 of these that I am making. I have a hydraulic press to do this with. Now maybe with this information I can get this done. Thanks everyone for pitching in to help!
Barry
Barry
