    Dismiss Notice
Precision Ground Toolroom Stones
Discussion in 'METROLOGY - MEASURE, SETUP & FIT' started by Bob Korves, Jun 12, 2017.
  1. ddickey
    ddickey United States H-M Supporter - Premium Content H-M Supporter-Premium
    355
    63
    City:
    Red Wing
    State:
    Minnesota
    -Return to Top-
    Looks like a new channel.
    tyler machine likes this.
  2. Cactus Farmer
    Cactus Farmer Active User Active Member
    150
    43
    City:
    Crane County
    State:
    Texas
    -Return to Top-
    I have a Rockwell T&C grinder that will do surface work too. I look for abused stones that are sometimes swaybacked to the max. I use a diamond wheel (I have several) to make the surface flat again. A little water mist coolant is in order as there is some heat generated. They appear to my gunsmith eye flat as a flitter (technical term) . Even hard Arkansas stones can be saved from the sad state of abuse they have suffered.
    4gsr likes this.
  3. benmychree
    benmychree United States Active User H-M Supporter-Premium
    310
    83
    City:
    Saint Helena
    State:
    California
    -Return to Top-
    I wonder what effect that the heat generated by the grinding has on the flatness of the stones; I know that with grinding steel parallels dry that it is near impossible to keep them (parallel) and straight, at least on the parallels that I made about 50 years ago of 0-1 tool steel, hardened; the heat of the cut would bow them up in the middle, even with the magnetic chuck on full power. Originally, I did not worry about exact nominal size, just parallelism; this was on a grinder 16 X 72" and not in good alignment, so I thought it might be nice to grind them to nominal size, but my B&S Micromaster does not currently have coolant and the results were not so good. I do not know how much effect that the lightening holes had and how much different a solid parallel would act but assume that it would make a difference. So, with stones ground dry, how flat is flat?
  4. Rex Walters
    Rex Walters Active Member Active Member
    184
    43
    City:
    Los Gatos
    State:
    California
    -Return to Top-
    Chips&More (Dave)'s comment earlier in the thread and yours puzzled me until I started reading about gage block stones.
    Starrett still sells stones expressly for removing burrs from gage blocks, which is simply amazing to me. See page 408 of their current catalog:
    The cheapest of them (for steel) appears to just be a small piece of granite that is precision ground. For ceramic or carbide they recommend their aluminum oxide stones (the larger one has serrations which apparently helps with the "feel" per Starrett). The granite stone is what has my attention, though.
    I think Dave may have it exactly right. The cheapest option for a "precision ground stone" may be simply a small, cheap granite surface plate.
    I'd be willing to bet that rubbing a hardened and ground part on a surface plate would burnish and identify high spots identically to what you see in Robin's video.
    Anyone here ever used any of those Starrett stones?
    Rex
    chips&more likes this.
  5. tyler machine
    tyler machine United States Iron Registered Member
    7
    3
    City:
    Fort Worth
    State:
    Texas
    -Return to Top-
    Just a flat granite block will define and burnish the high spots but it won't shear them off or improve the surface like a flattened aluminum oxide stone.
    Bob Korves likes this.
  6. maker of things
    maker of things United States Hermit H-M Supporter-Premium
    163
    43
    Michigan
    City:
    Zeeland
    State:
    Michigan
    -Return to Top-
    Heard about Robin's channel while watching Tom Lipton. I hope he makes a LOT more videos.
  7. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    3,394
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    That could be difficult to take to the work, depending on size, shape, and location. I also agree with Jon that it would only burnish, not remove burs.
  8. chips&more
    chips&more United States Active User Active Member
    1,185
    113
    City:
    Danville
    State:
    California
    -Return to Top-
    Yes Rex, I have been using a granite surface plate for a very long time for such purposes. I didn’t mention it earlier, sorry, but I also apply some Starrett granite cleaner as I’m doing the deburring. It really helps keep the shiners/skid marks off the surface of the stone if nothing else. The stone I use is about 9” X 12”. That kind of real estate is another big advantage over the smaller examples. I’m seeing on fleaBay that a replacement, if I bought new, would be about 50 bucks. Both the surface plate and sharpening stone are a good solution to deburr. I’m not deburring every day in my shop. It’s not a priority. But, it is a needed capability in my shop from time to time…Dave
  9. chips&more
    1,185
    113
    City:
    Danville
    State:
    California
    -Return to Top-
    Hi Bob, after a surface has been blemished it can no longer be the same. So then what? Do you remove the high spot(s)? Or do you try and push them back to where they were? When I recondition my Bridgeport mill table, I DO NOT RUN A FILE OVER ITS SURFACE. Instead, I have a large flat and heavy piece of cast iron that I slide all over the top of the table. This method burnishes the table. I dislike the thought of filing metal off. That will only change the landscape forever. If my precision whatever has a blemish and I’m concerned about it. I’m not that eager to try and remove it. I would rather burnish it. This of course depends on many factors. But I would try and burnish first…Dave
  10. tyler machine
    7
    3
    City:
    Fort Worth
    State:
    Texas
    -Return to Top-
    Once a clamp, t-nut, 1-2-3 block, part or anything falls on or scratches a softer surface, then yes it's not the same. I can't see rubbing two cast iron surfaces together until both surfaces are free of raised material from scratches or dings. Looks like you would just be asking for them to gall each other and cause more damage.:(
  11. Rex Walters
    184
    43
    City:
    Los Gatos
    State:
    California
    -Return to Top-
    Intuitively, I'd also think that a granite surface plate would be terrible for removing a burr after dinging a precision ground surface. My intuition says a granite plate would only be good for burnishing and not for removing a burr.
    Yet Starrett sells a granite stone expressly for removing such burrs. Dave also reports success doing the same on a surface plate.
    I'm inclined to believe (especially with my humiliating lack of a surface grinder) that a precision ground 2" wide granite parallel might make a passable replacement for a precision ground stone like Robin shows in his video. Robin's stones might work better or faster due to the porosity of an India stone, but a shop grade granite surface plate might actually be cheaper than the commercial $500 stones that Robin mentions (for those of us that can't make our own).
    It might take some time and effort with an abrasive stone cutter or chisel, but a $30 surface plate could make a a half dozen or more small hand stones. I'm tempted to try it.
    This sounds truly outrageous, but I'm also wondering if a granite plate couldn't also be used as the final step to make a "precision ground" India stone. I want to try flattening an India stone on a diamond plate to get it relatively flat, then lapping it on a granite surface plate directly! I'm probably missing something, but I just don't understand why a stone lapped like that would have a substantially different surface than an India stone ground with a diamond wheel.
    This is all just a gedanken experiment for me at this point though. I have no experience at all with any of this.
    Rex
  12. Bob Korves
    3,394
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    If you are ever down in Montebello, go to Standridge Granite and talk them out of some cutoffs from making surface plates. Or any other surface plate maker, or tombstone maker, counter top maker or installer, or whatever. They should be free or dirt cheap. I would certainly not try cutting up granite myself. You will still need something like a surface grinder or similar to get the material flat enough so it will not damage the precision hardened steel surfaces when they are rubbed. I think the flattened India stones make the most sense over all, and the cost of the stones is negligible in the big picture. It is like the guys who want to make their own surface plates. By the time you get together all the stuff needed to make, calibrate, and qualify one, and work the learning curve, the couple/few hundred dollars one costs factory made pales when Standridge can whip out in a short time in a factory to a known and tested quantity. Why reinvent the wheel? At some point we should make the parts that all the fancy tooling is designed to help achieve. I know, life is a journey. Enjoy the ride. But, along the road, don't forget to also savor the fruits...
    I certainly will not be rubbing hardened steel with burs onto my surface plate that is calibrated to .000030" repeatability and .00015" accuracy over the entire 24x36" surface, and I am sure I would not do so on a small cheap import surface plate, if I had one, either.
  13. Rex Walters
    184
    43
    City:
    Los Gatos
    State:
    California
    -Return to Top-
    Sorry, Bob. I seem to have riled you.
    I'm talking (out of at least one orifice) about breaking a cheap $30 or $40 surface plate into a few pieces to play with, not attempting to flatten granite to surface plate standards in my garage! I'm pretty sure those pieces will have a surface as flat as anything I could make with my (nonexistent) surface grinder and an India stone.
    I wouldn't take a piece of hardened steel to anyone's expensive certified plate.
    Those cheap offshore granite plates aren't up to standridge standards, but they are pretty flat and surely flatter than a surface ground piece of soft aluminum oxide, aren't they? They are also cheap enough to use as a stone to remove burrs.
    Until you shut me up by sending me a couple of the stones you're making I'll keep thinking out loud since I don't have the means of making my own. ;-)
    Rex
  14. Bob Korves
    3,394
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Sorry if it sounded like I was riled, I often write more passionately than I actually feel. A remnant of strict schooling...
    I think I would leave any surface plate intact, even if it is destined for rubbing and lapping. A small cheap one would be fine for rubbing pieces on. Then I would find some granite remnants from a counter top installer for hand held stones for rubbing the parts. They should be flat enough for that (?)
    Rex Walters likes this.
Share This Page
