E
ecdez
Forum Guest
Register Today
So I finally got my RPC hooked up and running and got three of my five 3 phase machines going. They were fairly easy because they were pretty much plug and play. They had a cable coming out of the box and I hooked them up. This lathe has proved a little more challenging.
The lathe can be seen here by the way. http://www.hobby-machinist.com/showthread.php?t=16120
When I got the machine, the wiring was disconnected from the box so I have no frame of reference. Here's the pieces of the puzzle.
Thanks in advance for any guidance.
Electrical Box
First question - T1 and T3 are clearly labeled but where does T2 go? There's a diagram at the bottom for reference but I can't figure it out. Does it simply go to the center screw on the second row from the top?
Second question - Is the wiring of this switch really as simple as it looks?
Red (#1) goes to the L1 input side of the overload
White (#2) goes to the 2 on the front of the overload
Black (#3) goes to the 3 on the front of the overload
Electrical Box
