    Dismiss Notice
Power 24 volt DC Motor
Discussion in 'ELECTRICAL ISSUES - POWER YOUR MACHINES & SHOP' started by gwarner, Apr 23, 2017.
  1. gwarner
    gwarner United States Active Member Active Member
    52
    18
    City:
    Omaha
    State:
    Nebraska
    -Return to Top-
    I picked up an Auto scrubber that had 3 Motors. 1 motor is a .5 HP that drove the machine and 2 .75 HP motors that drove the floor scrub pads. These motors are big and weigh about 40+ pounds each.
    They are 24 volt DC. The .5 says it is 320 rpm and 23 amps. The .75 are geared and 200 rpm and 32 Amps.
    I don't need to do any speed control but I want to power them from a 120 volt circuit and convert it to 24 volts if possible.
    I have found a few converters that go as high as 20 amps but none in the 30 amp range.
    Short of hooking them up to batteries what is the best way for me to power these motors.
    I want to use them on a mill if possible.
    Any thing you guys aware of that is out there?
  2. CluelessNewB
    CluelessNewB Active Resistor H-M Supporter-Premium
    403
    83
    United States Southern Maine
    City:
    Gorham
    State:
    Maine
    -Return to Top-
  3. Tony Wells
    Tony Wells United States Former Vice President Staff Member Administrator
    19,405
    113
    Tyler, Texas
    City:
    Tyler
    State:
    Texas
    -Return to Top-
    Probably going to have to build something. Might be quite a bit cheaper anyway.
  4. brino
    brino Active User H-M Supporter-Premium
    2,295
    113
    City:
    Almonte
    State:
    Ontario
    -Return to Top-
    Hey there is a thread on here about rewiring a microwave oven transformer for a power supply.
    http://www.hobby-machinist.com/threads/rewiring-a-mot-microwave-oven-transformer.57223/
    http://www.hobby-machinist.com/thre...rger-from-a-microwave-oven-transformer.57271/
    and in fact, that first one goes thru the process of testing the transformer with a few turn to work out the volts per turn. Using that you can figure out the number of turns required for your target output voltage.
    ebay would be a good source for a high-current bridge rectifier and capacitors.
    It is a total DIY solution, low cost and not overwhelming complexity if you've done any electrical\electronics work before.
    -brino
    EDIT: you could also check either agricultural or industrial markets for 24V battery chargers that can supply the current you need.
  5. RJSakowski
    RJSakowski H-M Supporter - Premium Content H-M Supporter-Premium
    2,600
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
  6. Silverbullet
    Silverbullet Active Member Active Member
    864
    113
    City:
    Marlton
    State:
    New Jersey
    -Return to Top-
    If you were close we could deal for a 24 volt charger from walk behind pallet jacks. Id look into a charger for power wheelchair and scooters. I needed one for a scooter I use , not sure if ebay or amazon. But I think I paid about thirty bucks but not sure of the output on that.
    Ulma Doctor likes this.
  7. gwarner
    52
    18
    City:
    Omaha
    State:
    Nebraska
    -Return to Top-
    Thanks for all the replies. You guys had better luck that what I did. Those are a pricey gamble since I'm not certain the motors will work out for the application.
    I like the idea of the 24 volt charger seems that may be an easy find. Will it put out constant voltage to run the motors for a long time?
    I do have a larger transformer that I pulled from something. I will test later today to see what it puts out.
    I am good with wiring a house but Electronics is my nemesis. I am only good at letting the smoke out.
    Brino, I can follow instructions so I may pursue the DIY solution if my Transformer is in the range I'm hoping.
    Glenn Brooks and brino like this.
  8. David S
    David S Canada Active User H-M Supporter-Premium
    641
    113
    Brockville, Ontario
    City:
    Brockville
    State:
    Ontario
    -Return to Top-
    Depending on the type of motor the start up current is going to be brutal. Series motors of that size will probably be over 100 amps. At 24 volts this can be tough on switches, contactors, etc.
    Now if the actual running load will be much less than the rated that will help. I don't think a normal charge will like this type of load. Also some chargers are "smart" and they won't start unless they see a minimum voltage, this protects everything in case the output terminals get shorted together.
    One way would be to use a 24 volt battery (two 12s in series) to handle the peak inrush, and if the running current is low use a charger that can handle the running current.
    David
    brino likes this.
  9. markba633csi
    markba633csi United States Active Member Active Member
    400
    83
    City:
    Mountain View
    State:
    California
    -Return to Top-
    A small DC arc/mig welder sounds like just the ticket- they put out about the right voltage and 80 or so amps...
    Mark S.
    ps those motors sound like they would be more suited to a small electric vehicle rather than a mill.
    brino likes this.
  10. CluelessNewB
    403
    83
    City:
    Gorham
    State:
    Maine
    -Return to Top-
    For testing purposes two 12V automotive batteries in series would give you 24V. You could at least determine if the motors work before you invest money (or time) in a power supply.
    Heck you could even try them using just one 12v battery you wouldn't get full power but they should turn.
    brino likes this.
  11. David S
    641
    113
    Brockville, Ontario
    City:
    Brockville
    State:
    Ontario
    -Return to Top-
    Rich suggestion is a good one. At half voltage they will have 1/4 max watts out, but for your purpose that may be ok. Speed will be half as well.
    David
  12. Keith Foor
    Keith Foor Active Member Active Member
    198
    43
    City:
    Johnstown
    State:
    Ohio
    -Return to Top-
    For what a 24 volt power supply is going to cost to run those motors, I would be looking for a couple used gear motors and using them instead.
    I am betting that you can get a used motor with a gear reduction for the cost of the power supply.
    If you are set on doing it. I figure you could locate a 24 volt forklift battery changer that would do the job but 24 volts at 35 amps is going to be 220 most likely. Most of the power supplies you seek are going to be transformer based and about 60% efficient.
    If you are dedicated to the effort, look at Duracomm's web site and give them a call.
    They should be able to help you out but it's not going to come cheap.
  13. RJSakowski
    2,600
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
    A 3/4 hp motor puts out 560 watts of power. The electrical power in will be somewhat higher. At 24 volts, that works out to around 23 amps. 3/4 hp is not a lot of motor for a mill so I would expect that you would be loading the motor fairly well and need the better part of that 23 amps.
    As an aside, if the motor is not a permanent magnet type, you should be able to run it on ac. You would then just require a transformer which is easier to find than a dc power supply at that current draw..
  14. gwarner
    52
    18
    City:
    Omaha
    State:
    Nebraska
    -Return to Top-
    Well I have come up with something I plan to try. The motors when spun basically become generators.
    I hooked the 2 .75 motors together and as I spun it by hand the other one spun at about the same speed.
    I am going to try and power one of them from a 120 volt AC motor.
    What are you thoughts on this working. Any protection like fuses etc I need to put between them?
    Will I need to try and match the specified rpms? What if I turn them at 1750?
    What am I overlooking here?
  15. Keith Foor
    198
    43
    City:
    Johnstown
    State:
    Ohio
    -Return to Top-
    If the output RPM is 320 then turning them at 1750 may cause issues. Figure that the motor is spinning at 1750 or so when the output shaft is running 320. So if you spin the shaft at 1750 the motor will be turning along at just shy of 10K RPM. Gonna guess that the motor will not be impressed.
  16. brino
    2,295
    113
    City:
    Almonte
    State:
    Ontario
    -Return to Top-
    .....and if any of them use worm-gear speed reduction, you won't be able to turn those output shafts!
    -brino
  17. Ulma Doctor
    Ulma Doctor Infinitely Curious Active Member
    3,000
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    you may be able to remove the gear reduction units from the motors and devise further from ther
  18. markba633csi
    400
    83
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Yes it will work but inefficient
Share This Page
